    Selected entity question
    8 Posts 3 Posters 7.8k Views 3 Watching
    • PixeroP
      Pixero
      Short question.
      Is:
      Sketchup.active_model.active_entities[0]
      the selected entity?
      • jiminy-billy-bobJ
        jiminy-billy-bob
        No, these are the entities in the open group or component instance.
        You want:
        Sketchup.active_model.selection[0]
        http://ruby.sketchup.com/Sketchup/Selection.html
        • PixeroP
          Pixero
          Thanks. That was what I suspected.
          Now I need to find a way to do what I want to do from the selection.
          A side question. What about getting the selected material?
          Sketchup.active_model.materials[0] won’t do it then either I guess?
          • jiminy-billy-bobJ
            jiminy-billy-bob
            That would be Sketchup.active_model.materials.current
            • TIGT
              That method gives you the current 'active' material in the model.
              But... if you want to get a material from the currently selected entity, then you use:
              mat = Sketchup.active_model.selection[0].material
              However, you might be better off filtering the selection, until you get an entity of the kind you want... e.g.
              face = Sketchup.active_model.selection.grep(Sketchup;;Face)[0]
              mat = nil
              mat = face.material if face
              Where the first face in the selection returns its material, or nil...
              • PixeroP
                Pixero
                Thanks, I read in a older post somewhere, and I think it was by Thomthom, that there was a bug that could Bugsplat SU when using materials.current if there wasn't any materials in SU. Do you know if that still is an issue or if it has been fixed?
                • TIGT
                  Why do you need to get the model.materials.current ?
                  You could pre-set it using model.materials.current = a_material
                  Having previously set a_material = model.materials["A_Name"]
                  You haven't really explained the full context......
                  • PixeroP
                    Pixero
                    They are just for two small snippets that I will need some advise from Thomasz (Thea settings) to make them properly.
                    I'm just preparing for when he will have some time to look into it...
