    Selected entity question
    8 Posts 3 Posters 7.3k Views 3 Watching
    • PixeroP Offline
      Pixero
      Short question.
      Is:
      Sketchup.active_model.active_entities[0]
      the selected entity?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        No, these are the entities in the open group or component instance.
        You want:
        Sketchup.active_model.selection[0]
        Class: Sketchup::Selection
        A set of the currently selected drawing elements.
        SketchUp Ruby API Documentation (ruby.sketchup.com)
        • PixeroP Offline
          Pixero
          Thanks. That was what I suspected.
          Now I need to find a way to do what I want to do from the selection.
          A side question. What about getting the selected material?
          Sketchup.active_model.materials[0] won’t do it then either I guess?
            jiminy-billy-bob
            That would be Sketchup.active_model.materials.current
              That method gives you the current 'active' material in the model.
              But... if you want to get a material from the currently selected entity, then you use:
              mat = Sketchup.active_model.selection[0].material
              However, you might be better off filtering the selection, until you get an entity of the kind you want... e.g.
              face = Sketchup.active_model.selection.grep(Sketchup;;Face)[0]
              mat = nil
              mat = face.material if face
              Where the first face in the selection returns its material, or nil...
              • PixeroP Offline
                Pixero
                Thanks, I read in a older post somewhere, and I think it was by Thomthom, that there was a bug that could Bugsplat SU when using materials.current if there wasn't any materials in SU. Do you know if that still is an issue or if it has been fixed?
                  Why do you need to get the model.materials.current ?
                  You could pre-set it using model.materials.current = a_material
                  Having previously set a_material = model.materials["A_Name"]
                  You haven't really explained the full context......
                  • PixeroP Offline
                    Pixero
                    They are just for two small snippets that I will need some advise from Thomasz (Thea settings) to make them properly.
                    I'm just preparing for when he will have some time to look into it...
