    Number of Circle segments
    5 Posts 3 Posters 1.1k Views 3 Watching
    • pbacotP Offline
      I get a warning quite often when I change the number of segments in a circle. I type in something like 96 and I get the warning about the range. Sometimes the edit just works, other times I have to redo. I am in the range so I wonder if there is something I am missing.
        That's odd. Where are you changing this value? In Entity Info?
          This can sometimes occur due to input error either adding or removing digits.
          • pbacotP Offline
            Yes, Mike but it happens in this case a lot and I am pretry goood at typoiing otherwise.
            I usually do it in the entity window, and since I get this message often I look at what I am typing. And this has happened to me in different versions of SU.
            It's possible typing "s" afterward helps some of the time.
              Sorry. That made me laugh.
              "s" shouldn't be necessary in Entity Info. It used to be required if you were making the adjustment before drawing a circle but it isn't anymore.
              When you are changing the setting in Entity Info, are you selecting the existing number and then just overtyping? Or are you selecting the existing value and deleting it before typing the new number?
