    Bathroom interior
    19 Posts 8 Posters 3.4k Views 8 Watching
    • majidM Offline
      majid
      I modeled this based on a real project I saw on the web, I guess it was a Spanish farm house reconstruction or something.
      Model in Sketchup (+ 3dwarehouse), Blender 3D , rendered in Thea.
      • tuna1957T Offline
        tuna1957
        Excellent πŸ‘
        • pbacotP Offline
          Very cool subject and "photographs"!Captured the feel. I want to rent it for the holidays.
          • majidM Offline
            majid
            Thank you mates, this is done based on images of this project:
            https://www.archilovers.com/projects/237129/gallery?2248428
              Fantastic, Majid. I think you posted photo's by mistake though. β˜€ πŸ˜„
              • majidM Offline
                majid
                Thanks Mike , I am overwhelmed...
                • majidM Offline
                  majid
                  Just to know material ,light and camera setup took 11 min and render time is 4 min per frame.
                  • Bryan KB Offline
                    Sure looks like it! πŸ‘
                    • majidM Offline
                      majid
                      Thanks, By the way it could be ways better. Some imperfection some material improvement and also display settings such as better CRF file and white balance etc..
                      • boofredlayB Offline
                        boofredlay
                        These are great. Could pass for photos no doubt!
                        • majidM Offline
                          majid
                          Thank you Sir.
                          This is a warmer version.
                          • cheddaC Offline
                            chedda
                            Very good Majid the contrast and saturation make the first images pop.
                            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                            • majidM Offline
                              majid
                              Thank you Chedda, this means great for me , having endorse from a master as you.
                              • majidM Offline
                                majid
                                Presto engine provides cool stereoscopic renders.
                                • jo-keJ Offline
                                  jo-ke
                                  This is interessting. Did you set one point and presto sets both points to render by itself?
                                  Is it possible to render a stereoscopic walkthrough animation in 180Β° for Oculus rift?
                                  I am very interessted in these possibilites!
                                  http://www.zz7.de
                                  • majidM Offline
                                    majid
                                    I have no idea how Oculus rift works,I mean if it needs a panoramic 360 image or 2 stereoscopic 360 degree... etc. but as I know Thea is capable of using 3 different camera types to render: Standard, spherical and cylindrical and so must probably it is capable of doing such renders.
                                    About the setting, I set the camera focus distance on the far vase and eye distance to 6 cm and Thea did the rest.
                                    • jo-keJ Offline
                                      jo-ke
                                      Thank you majid, this is more than Twilight/Kerkythea can do.
                                      Stereoscopic 360 degree is a tricky thing, because of distortion. I would be glad if Thea can do this automatically.
                                      I wrote a tutorial about doing this manually. not really easy...
                                      https://sketchucation.com/forums/viewtopic.php?f=18&t=68015&p=647136#p647136
                                      In case of walkthroughvideo:
                                      I need two 180Β° views, one for each eye. they need to have always the same distance to another and need to walk from one to another cam postion...
                                      didn't find anything like that so far....
                                      http://www.zz7.de
                                      • majidM Offline
                                        majid
                                        Comprehensive tutorial.
                                        Thea has several options to provide stereo graphic images and I guess you can do lot with it... It has an initial eye distance that is adjustable and it may provide top/down results that I think speeds up the Panoramic view.
                                        • jo-keJ Offline
                                          jo-ke
                                          thank you for your help.
                                          http://www.zz7.de
