Bathroom interior
Just to know material ,light and camera setup took 11 min and render time is 4 min per frame.
@mike amos said:
Fantastic, Majid. I think you posted photo's by mistake though.
Sure looks like it!
These are great. Could pass for photos no doubt!
Thank you Sir.
This is a warmer version.
Very good Majid the contrast and saturation make the first images pop.
Thank you Chedda, this means great for me , having endorse from a master as you.
Presto engine provides cool stereoscopic renders.
This is interessting. Did you set one point and presto sets both points to render by itself?
Is it possible to render a stereoscopic walkthrough animation in 180Β° for Oculus rift?
I am very interessted in these possibilites!
I have no idea how Oculus rift works,I mean if it needs a panoramic 360 image or 2 stereoscopic 360 degree... etc. but as I know Thea is capable of using 3 different camera types to render: Standard, spherical and cylindrical and so must probably it is capable of doing such renders.
About the setting, I set the camera focus distance on the far vase and eye distance to 6 cm and Thea did the rest. -
Thank you majid, this is more than Twilight/Kerkythea can do.
Stereoscopic 360 degree is a tricky thing, because of distortion. I would be glad if Thea can do this automatically.
I wrote a tutorial about doing this manually. not really easy...
In case of walkthroughvideo:
I need two 180Β° views, one for each eye. they need to have always the same distance to another and need to walk from one to another cam postion...
didn't find anything like that so far....
Comprehensive tutorial.
Thea has several options to provide stereo graphic images and I guess you can do lot with it... It has an initial eye distance that is adjustable and it may provide top/down results that I think speeds up the Panoramic view. -
thank you for your help.
