    ExtentionStore 3.1. window is absolutely empty
    extensions
    10 Posts 3 Posters 3.9k Views 3 Watching
    • P
      polly_di
      ExtentionStore 3.1. window is absolutely empty. Internet connection is OK. Please help
      • G
        Gábor
        Which version are you using? Have you downloaded and installed the latest? Here it is: https://sketchucation.com/pluginstore?pln=SketchUcationTools
        Are you on a corporate network behind a firewall?
        Could you attach a screenshot of what you see please?
        • TIGT
          Please do as Gábor suggests...
          You could also try clearing the cache for Internet Explorer.
          In the case of the ExtensionStore² SketchUp uses IE to create its complex dialogs, irrespective of your own browser use or preferences...
          • P
            polly_di
            I use sketchup at home. The version is 3.1.7 - may be this is a problem? I'll try to install 3.1.8
            • P
              polly_di
              Cannot uninstall Scetchucation 3.1.7. Tryed to install 3.1.8. version - it doesn't appear either. The screenshot enclosed
              • G
                Gábor
                You do not need to uninstall it. You can simply install 3.1.8 and it will overwrite 3.1.7. Have you done the IE cache erase TIG suggested? I can not see the "enclosed" screenshot. Maybe something went wrong when you posted it.
                • P
                  polly_di
                  Yes, I clened IE cash, installed 3.1.8. through Extention Manager, but there still remains 3.1.7, I don't understand why
                  • P
                    polly_di
                    Снимок8.JPGattaching the print screen file
                    • TIGT
                      Those dialogs say SketchUcation... v3.1.7 - the current version is v3.1.8 - please up date to that [although with v2017 it shouldn't cause problems !] and restart SketchUp...
                      Next ideas...
                      In your Internet Options [Control Panel] - is it set to Medium/High security, and Medium for 'trusted sites' ?
                      Many dialogs use Javascript.
                      Do you have scripts 'enabled' in Internet Options ?
                      Gábor ?
                      Also... when you installed v2017 did you do it correctly.
                      Here's a 'repair' fix, that will do no harm and leave any existing customization unchanged...
                      While logged into Windows as your usual 'user'.
                      Close SketchUp.
                      Find its installer exe file - probably in your Downloads folder ?
                      Select the installer's icon, right-click > context-menu > "Run as administrator"
                      When prompted choose 'Repair'.
                      When it completes, restart SketchUp and retest.
                      Installing a complex app, like SketchUp, in any other way, will cause unpredictable issues...
                      Often with 'permissions'.
                      Even if you are an administrator just 'running' the installer - e.g. by double clicking its icon - is NOT the same as doing it the right way.
                      • G
                        Gábor
                        I'm not sure if it is anything to do with the problem but I see your attached images are named with Cyrillic characters(?). Does the path to your plugins folder contains non-ASCII characters? Username ?
