    Medeek Project
    112 Posts 3 Posters 14.6k Views 4 Watching
    • medeekM
      medeek
      The House Builder is a fair bit more complicated than the Garage Builder so I have my head buried in the code for a few days with little to show for all my work. Here is a first look at some of the interface with a few random walls arranged for testing.
      Notice the Start and End markers, similar to the Wall plugin. These will be an optional feature that can be toggled on or off. This is turning out to be a very interesting project and also quite challenging.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        First look at some walls with dimensions added:
        I was going to setup an auto-dimension algorithm. However after building the manual dimension tool I found it so easy to use that I don't really see a reason to bother with auto dimensioning. What you see here I was able to do in about 2-3 minutes.
        design.medeek.com
        • medeekM
          medeek
          I still have some rough edges to work on in the UI but progress is being made:
          All dimensions are associative, there is no concept of an orphaned dimension, however I may eventually change my mind on that. The nice thing about associative dimensions is that when you change the location of a wall or opening all of the dimensions auto-update.
          design.medeek.com
          • medeekM
            medeek
            Starting to work on the updated Elevations tab. Remember this is simply for preview purposes and not really designed to give a high fidelity (rendered) views of the structure/house.
            Also I haven't even started with the roof yet. I'm still trying to figure out how involved I want to make that. I could just have it take the wall perimeter and build a complex roof (all hip) using my weighted straight skeleton algorithm. Additionally I could also allow the user the ability to modify certain roof planes (ie. gable, dutch gable, half hip etc...) I will need to give this some additional thought.
            The same applies to the foundation (SOG vs. Stemwall) and then if a stemwall we need a floor framing plan. Also what do we do with a multi-story house? I think I've opened another can of worms.
            design.medeek.com
            • medeekM
              medeek
              I've also added a "visibility reference" icon/tool. This allows one to not only toggle off the grid but also to toggle on or off the 1st level walls below the 2nd level walls. This should aid in lining up walls on different levels.
              I'm also working on multi-levels, so things are getting interesting.
              design.medeek.com
              • medeekM
                medeek
                Adding the ability to move edges and vertices:
                design.medeek.com
                • medeekM
                  medeek
                  We can also add and delete vertices:
                  design.medeek.com
                  • medeekM
                    medeek
                    After adding some geometry: Rim Board, Sill Plate, Opening Headers and Joists.
                    design.medeek.com
                    • medeekM
                      medeek
                      We also need to be able to create annotations with and without leaders.
                      design.medeek.com
                      • medeekM
                        medeek
                        We also now a have a rudimentary line tool to manually draw in extraneous geometry or create tables etc... The line weight, line type and line color can be set, very similar to AutoCAD.
                        design.medeek.com
                          Is this a standalone app?
                          medeekM 1 Reply Last reply
                          • medeekM
                            medeek
                            I’ve only invested about a week’s worth of my time and energy into this new House Builder tool/app. I’m excited that I’ve been able to move it along quite quickly, thanks to the work I had already done with Garage Builder. I will need to circle back actually and add some of this increased functionality into the Garage Builder but for now my focus is on the House Builder since it is the more general tool.
                            I am really hoping that this tool will be as useful and well adopted as I think it will be. To that end I am investing quite a bit of time into it and will probably spend at least a couple more weeks sorting out all the intricacies of wiring up complex roofs and multi foundation types. I think we almost have the floor framing portion completed.
                            With the addition of more common drafting style tools (ie. dimensions, callouts, text, text /w leaders and lines) the tool has become much more interactive and the user experience or UI will be of paramount importance. I don’t want this tool to feel clunky so it may require a few iterations to fine tune these tools until they are a “joy to use”.
                            I think I will probably release an update of the plugin even before I’ve waded into the foundations and roofs so that the power users can begin poking and prodding this thing and expose its weaknesses
                            design.medeek.com
                            • medeekM
                              medeek @Rich O Brien
                              No, it is part of the Medeek Project plugin that runs inside of SketchUp.
                              However you do bring up a very interesting point. Other than the one action of "Create Building" where the tool then sends all of the commands to the Medeek API to generate all of the geometry, this entire tool could be its own stand alone app. I am actually considering that.
                              design.medeek.com
                              • medeekM
                                medeek
                                I've also decided to add a move/copy tool and a polyline tool.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Testing the reference underlays for the Upper Floor Plan (level 1 wall framing and level 2 floor framing):
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    First look at some complex roofs in the Roof Plan tab:
                                    I will need to stress test it further to see if we can break it. The solver algorithm is borrowed directly from the new weighted straight skeleton solver I implemented about a month ago in the Truss plugin, no point in reinventing the wheel.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Editing a complex roof:
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        First look at an elevation view of a simple house plan with a complex roof:
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          The roof overlay has now been added to the Floor Plan and the Upper Floor Plan:
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Complex roofs is still a work in progress, no surprise there. The interface will mirror the Truss plugin since we already know how that works. When a roof is selected the "custom" roof planes (edges) will display in red rather than blue. A selected edge will switch to a solid color and the right hand menu will display the settings for that roof plane.
                                            The same settings that are available in the Truss plugin will appear for the selected "roof plane type".
                                            design.medeek.com
                                            • 6
                                            • 4 / 6
