    Medeek Project
    94 Posts 3 Posters 11.3k Views 4 Watching
    • medeekM
      medeek
      Tutorial 2 - Title Blocks (16:33 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        First look at the Seismic tab of the Project Info tool:
        https://global.discourse-cdn.com/sketchup/original/3X/e/3/e3dac50a83a157e88e53d38fddaffb4536c767cb.jpeg
        I wish my KML overlay was a little more transparent but it seems to work for now.
        I just need to implement the code that connects to the USGS API which pulls all of this seismic data from their database.
        design.medeek.com
        • medeekM
          medeek
          Version 1.0.4 - 01.29.2023
          • Added the Seismic tab to the Project Information tool.
          • Added site parameters (Building Standard, Risk Category, Site Soil Class) to the General Data tab of the Project Information tool.
          • Enabled the USGS lookup tool for the following standards: ASCE7-10, ASCE7-16, ASCE7-22.
          This tab is not quite complete. I would like to add a button which allows one to automatically generate a PDF report with the seismic data. Most of the code for that tool/feature is already in place but I need to still figure out the details between the integration of my website and the back end Ruby connection with SketchUp.
          Once that piece of the puzzle is added then this tool actually becomes useful in the real world.
          design.medeek.com
          • medeekM
            medeek
            Once you have enough information specified in the Seismic tab then the “Download PDF Report” button will appear:
            https://global.discourse-cdn.com/sketchup/original/3X/0/6/06d5c30e5e2124344b2e92c28bd63fe088ff9ecd.jpeg
            The PDF report will something like this (this one is actually a snow load report):
            https://global.discourse-cdn.com/sketchup/optimized/3X/d/5/d521a169ab330eabd513010ad2bedbe70a587f39_2_383x500.jpeg
            design.medeek.com
            • medeekM
              medeek
              Version 1.0.5 - 02.04.2023
              • Enabled a PDF Seismic Report generator within the Seismic tab of the Project Information tool.
              https://global.discourse-cdn.com/sketchup/optimized/3X/0/5/0581531707e645a5b3ac8de2801e2e2ff8a110a2_2_384x500.jpeg
              https://forums.sketchup.com/uploads/short-url/n033ufC1CYEjTuq6zTHraGs6xX8.pdf
              design.medeek.com
              • medeekM
                medeek
                Tutorial 3 - Seismic Reports (9:28 min.)
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.0.6 - 02.06.2023
                  • Fixed a bug with the Title Block Tool.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.0.7 - 02.08.2023
                    • Added optional labels (x-axis and/or y-axis) for major grid lines within the Grid Tool.
                    http://design.medeek.com/resources/projectplugin/images/project_su23_800.jpg
                    http://design.medeek.com/resources/projectplugin/images/project_su24_800.jpg
                    This additional feature per customer request.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.0.8 - 02.12.2023
                      • Added floor layers to the Layer Control Tool.
                      http://design.medeek.com/resources/projectplugin/images/project_su25_800.jpg
                      Note the Floor plugin has not yet been released, this update is in preparation for when it is released.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.0.8b - 02.13.2023
                        • Fixed a bug in the Estimating module for king stud quantities for windows and doors (metric units).
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.0.9 - 03.10.2023
                          • Fixed a bug with the Trim 3 tool.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.1.0 - 07.01.2023
                            • Enabled FIS notation for dimensions in the General tab of the Global Settings.
                            • Added rafter lengths (with total length or minimum stock length) for gable and hip rafter roofs within the Medeek Estimator.
                            http://design.medeek.com/resources/projectplugin/images/project_su27_800.jpg
                            http://design.medeek.com/resources/projectplugin/images/project_su26_800.jpg
                            The rafter lengths are currently only available for imperial units. If I get requests for this to be extended to metric units I will make this also available for metric units.
                            The rafter length in this case is actually the rafter length minus the overhang, so technically it is the length to the seat cut.
                            https://global.discourse-cdn.com/sketchup/optimized/3X/2/7/27cc852c1a571a27fe926f23e0b8591f310daf2f_2_600x500.gif
                            design.medeek.com
                            • medeekM
                              medeek
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.1 - 07.30.2023
                                • Updated the estimating module to provide more granular data for wall top plates.
                                *Note: If this updated version is installed then Version 3.2.3 of the Wall plugin is required in order to obtain wall top plate data.
                                This update per customer request.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.1.2 - 08.01.2023
                                  • Updated the estimating module to provide location data (within a wall) for windows, doors, garage doors and in-wall columns.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.1.3 - 09.06.2023
                                    • Updated the scene generator to include gable, shed and hip walls.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.1.4 - 07.01.2023
                                      • Added complex rafter roofs within the Medeek Estimator.
                                      • Added rafter labels (total length) for complex rafter roofs within the Medeek Estimator.
                                      http://design.medeek.com/resources/projectplugin/images/project_su28_800.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.1.5 - 01.23.2024
                                        • Fixed a bug with the Extend Tool for groups (and components) that share the same definition.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.1.6 - 02.13.2024
                                          • Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
                                          http://design.medeek.com/resources/projectplugin/images/project_su31_800.jpg
                                          There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations. This is just a start.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.1.7 - 02.17.2024
                                            • Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
                                            http://design.medeek.com/resources/projectplugin/images/project_su32_800.jpg
                                            Per customer request.
                                            design.medeek.com
                                            • 2 / 5
