    Medeek Project
    122 Posts 3 Posters 18.1k Views 4 Watching
    • medeekM
      medeek
      Version 1.0.2c - 01.17.2023
      • Fixed a namespace bug with the Grid Tool.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.0.2d - 01.19.2023
        • Optimized the Google Map API portion of the Project Info tool.
        • Choice of map type made persistent across different sessions.
        Tutorial 1: Introduction (20.01 min.)
        design.medeek.com
        • medeekM
          medeek
          First look at the EOR tab:
          https://global.discourse-cdn.com/sketchup/original/3X/9/9/990e922ccf1166f6cd56682be616aade52192d7d.jpeg
          design.medeek.com
          • medeekM
            medeek
            First look at the AOR tab:
            https://global.discourse-cdn.com/sketchup/original/3X/f/2/f22f24c9b235062932e4c487e0eb6c2fef1b358f.jpeg
            design.medeek.com
            • medeekM
              medeek
              First look at the Title Block tool in action:
              https://global.discourse-cdn.com/sketchup/optimized/3X/a/b/abee7acd0b238ae14b26139de63585106a490ff5_2_690x436.jpeg
              https://global.discourse-cdn.com/sketchup/optimized/3X/6/b/6b3b2795d4df24e9a5b6020f7f8b3023cc3ff82d_2_690x201.jpeg
              Note that these title blocks are being drawn in SketchUp not Layout so they may only have limited utility but I think they still may be useful for those wanting to quickly throw together something for presentation purpose.
              The Customer, Architect/Designer and Engineers data is pulled as the default but all of this information can be customized completely.
              I call this title block a "no frills" title block, just a functional element that is simply meant to convey the most basic information.
              design.medeek.com
              • medeekM
                medeek
                Version 1.0.3 - 01.26.2023
                • Added the EOR tab to the Project Information tool.
                • Added the AOR tab to the Project Information tool.
                • Added the Title Block Tool to the main toolbar.
                • Added a parametric Title Block tool.
                Let me know what you all think of this feature. Again I don't believe this should replace a proper Title Block in Layout but it will offer a quick and dirty solution in SketchUp for those who don't need or want to go into Layout.
                I should probably also put out a short tutorial video on this feature and now it integrates with the Project Information data.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 2 - Title Blocks (16:33 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at the Seismic tab of the Project Info tool:
                    https://global.discourse-cdn.com/sketchup/original/3X/e/3/e3dac50a83a157e88e53d38fddaffb4536c767cb.jpeg
                    I wish my KML overlay was a little more transparent but it seems to work for now.
                    I just need to implement the code that connects to the USGS API which pulls all of this seismic data from their database.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.0.4 - 01.29.2023
                      • Added the Seismic tab to the Project Information tool.
                      • Added site parameters (Building Standard, Risk Category, Site Soil Class) to the General Data tab of the Project Information tool.
                      • Enabled the USGS lookup tool for the following standards: ASCE7-10, ASCE7-16, ASCE7-22.
                      This tab is not quite complete. I would like to add a button which allows one to automatically generate a PDF report with the seismic data. Most of the code for that tool/feature is already in place but I need to still figure out the details between the integration of my website and the back end Ruby connection with SketchUp.
                      Once that piece of the puzzle is added then this tool actually becomes useful in the real world.
                      design.medeek.com
                      • medeekM
                        medeek
                        Once you have enough information specified in the Seismic tab then the “Download PDF Report” button will appear:
                        https://global.discourse-cdn.com/sketchup/original/3X/0/6/06d5c30e5e2124344b2e92c28bd63fe088ff9ecd.jpeg
                        The PDF report will something like this (this one is actually a snow load report):
                        https://global.discourse-cdn.com/sketchup/optimized/3X/d/5/d521a169ab330eabd513010ad2bedbe70a587f39_2_383x500.jpeg
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.0.5 - 02.04.2023
                          • Enabled a PDF Seismic Report generator within the Seismic tab of the Project Information tool.
                          https://global.discourse-cdn.com/sketchup/optimized/3X/0/5/0581531707e645a5b3ac8de2801e2e2ff8a110a2_2_384x500.jpeg
                          https://forums.sketchup.com/uploads/short-url/n033ufC1CYEjTuq6zTHraGs6xX8.pdf
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 3 - Seismic Reports (9:28 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.0.6 - 02.06.2023
                              • Fixed a bug with the Title Block Tool.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.0.7 - 02.08.2023
                                • Added optional labels (x-axis and/or y-axis) for major grid lines within the Grid Tool.
                                http://design.medeek.com/resources/projectplugin/images/project_su23_800.jpg
                                http://design.medeek.com/resources/projectplugin/images/project_su24_800.jpg
                                This additional feature per customer request.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.0.8 - 02.12.2023
                                  • Added floor layers to the Layer Control Tool.
                                  http://design.medeek.com/resources/projectplugin/images/project_su25_800.jpg
                                  Note the Floor plugin has not yet been released, this update is in preparation for when it is released.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.0.8b - 02.13.2023
                                    • Fixed a bug in the Estimating module for king stud quantities for windows and doors (metric units).
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.0.9 - 03.10.2023
                                      • Fixed a bug with the Trim 3 tool.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.1.0 - 07.01.2023
                                        • Enabled FIS notation for dimensions in the General tab of the Global Settings.
                                        • Added rafter lengths (with total length or minimum stock length) for gable and hip rafter roofs within the Medeek Estimator.
                                        http://design.medeek.com/resources/projectplugin/images/project_su27_800.jpg
                                        http://design.medeek.com/resources/projectplugin/images/project_su26_800.jpg
                                        The rafter lengths are currently only available for imperial units. If I get requests for this to be extended to metric units I will make this also available for metric units.
                                        The rafter length in this case is actually the rafter length minus the overhang, so technically it is the length to the seat cut.
                                        https://global.discourse-cdn.com/sketchup/optimized/3X/2/7/27cc852c1a571a27fe926f23e0b8591f310daf2f_2_600x500.gif
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.1.1 - 07.30.2023
                                            • Updated the estimating module to provide more granular data for wall top plates.
                                            *Note: If this updated version is installed then Version 3.2.3 of the Wall plugin is required in order to obtain wall top plate data.
                                            This update per customer request.
                                            design.medeek.com
                                            • 2 / 7
