    Medeek Project
    106 Posts 3 Posters 13.2k Views 4 Watching
    • medeekM
      medeek
      Version 1.0.9 - 03.10.2023
      • Fixed a bug with the Trim 3 tool.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.1.0 - 07.01.2023
        • Enabled FIS notation for dimensions in the General tab of the Global Settings.
        • Added rafter lengths (with total length or minimum stock length) for gable and hip rafter roofs within the Medeek Estimator.
        http://design.medeek.com/resources/projectplugin/images/project_su27_800.jpg
        http://design.medeek.com/resources/projectplugin/images/project_su26_800.jpg
        The rafter lengths are currently only available for imperial units. If I get requests for this to be extended to metric units I will make this also available for metric units.
        The rafter length in this case is actually the rafter length minus the overhang, so technically it is the length to the seat cut.
        https://global.discourse-cdn.com/sketchup/optimized/3X/2/7/27cc852c1a571a27fe926f23e0b8591f310daf2f_2_600x500.gif
        design.medeek.com
        • medeekM
          medeek
          design.medeek.com
          • medeekM
            medeek
            Version 1.1.1 - 07.30.2023
            • Updated the estimating module to provide more granular data for wall top plates.
            *Note: If this updated version is installed then Version 3.2.3 of the Wall plugin is required in order to obtain wall top plate data.
            This update per customer request.
            design.medeek.com
            • medeekM
              medeek
              Version 1.1.2 - 08.01.2023
              • Updated the estimating module to provide location data (within a wall) for windows, doors, garage doors and in-wall columns.
              design.medeek.com
              • medeekM
                medeek
                Version 1.1.3 - 09.06.2023
                • Updated the scene generator to include gable, shed and hip walls.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.1.4 - 07.01.2023
                  • Added complex rafter roofs within the Medeek Estimator.
                  • Added rafter labels (total length) for complex rafter roofs within the Medeek Estimator.
                  http://design.medeek.com/resources/projectplugin/images/project_su28_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.1.5 - 01.23.2024
                    • Fixed a bug with the Extend Tool for groups (and components) that share the same definition.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.1.6 - 02.13.2024
                      • Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
                      http://design.medeek.com/resources/projectplugin/images/project_su31_800.jpg
                      There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations. This is just a start.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.1.7 - 02.17.2024
                        • Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
                        http://design.medeek.com/resources/projectplugin/images/project_su32_800.jpg
                        Per customer request.
                        design.medeek.com
                        • medeekM
                          medeek
                          Tutorial 5 - Estimating Custom Rebar (12:15 min.)
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.1.8 - 02.21.2024
                            • Updated custom rebar within the Medeek Estimator to include unit and total length.
                            • Added custom rebar within the Medeek Estimator for Slab, Stemwall and Grade Beam foundations.
                            • Updated the Medeek Estimator so that multi-ply (custom) Window and Door headers are properly called out and quantified.
                            • Added additional logic into the Medeek Estimator so that assemblies are ordered in the report logically by their assembly names.
                            http://design.medeek.com/resources/projectplugin/images/project_su33_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.1.8b - 02.21.2024
                              • Fixed a bug in the ordering logic and a typo in the HTML preview menu.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.9 - 03.22.2024
                                • Added a Weight Database to the Medeek Estimating Module.
                                • Enabled Weight Analysis to the Medeek Estimating Module for Rectangular Wall Panels.
                                • Fixed some minor bugs with the estimating module for wall panels.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.2.0 - 03.23.2024
                                  • Added Headers (window, door, garage) for walls within the Medeek Estimating Module.
                                  • Added Blocking for walls within the Medeek Estimating Module.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.2.1 - 03.27.2024
                                    • Added cost analysis for windows units in walls within the Medeek Estimating Module.
                                    • Added additional logic into the Medeek Scene Generator so that assemblies are ordered in the report logically by their assembly names.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Medeek Project Plugin Tutorial 6 - Estimating Weights and Costs (13:52)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.2.2 - 04.20.2024
                                        • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.2.3 - 05.14.2024 thru 05.15.2024
                                          • Fixed a minor bug with the estimating module (wall header library initialization).
                                          • Fixed a minor bug with the estimating module (wall material library initialization).
                                          design.medeek.com
                                          medeekM 1 Reply Last reply
                                          • medeekM
                                            medeek @medeek
                                            Version 1.2.4 - 08.04.2024
                                            • Added a duplicate title block assembly check to the regen module for all title blocks.
                                            • Enabled wall sheathing 2 within the Medeek Estimating Module for wall assemblies.
                                            design.medeek.com
                                            • 2 / 6
