    Creating relistic grass using vray fur
    renderpluginsextensions
    8 Posts 3 Posters 3.9k Views 3 Watching
      Dprince
      Im unable to render large portions of grass when i use vray 3.4 with fur tool it comes with. Every time i try it freezes. any suggestion on how to remedy this?
      • V Offline
        valerostudio
        Turn on Level of Detail in the fur options. You might be asking a lot of your machine with such a large area.
          Dprince
          that is already turned on. is it a case where i need to make adjustments to the default settings?
            Dprince
            this is the area i need realistic grass and the other pic is the vray setting. which is default? im not sure what to adjust it to
            tha
            vray setting
            • majidM Offline
              majid
              Reduce the knots to a lower value, maybe 3-1 then you might tweak the too close grass using Photoshop , etc. if needed.
                Dprince
                • majidM Offline
                  majid
                  Would be nice if please share the result.
                    Dprince
                    Everything worked find thanks a lot again.
