    Animator Follow Path
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    4 Posts 2 Posters 6.9k Views 2 Watching
      Mayoketchup
      Hello
      I'm trying to create an animation where an object follows a path. I'm using Fredo6's animator but I can't select a path after I selected the object. Am I doing something wrong ? I'm using SU 2018 pro.
      • fredo6F Offline
        fredo6
        @mayoketchup said:
        HI'm using Fredo6's animator but I can't select a path after I selected the object. Am I doing something wrong ? I'm using SU 2018 pro.
        Make sure the path are native Sketchup curves. Then they should be selectable from Animator Follow Path tool.
          Mayoketchup
          Hey Fredo
          I noticed it doesn't work with native lines only with freehand and arcs.
          I downloaded your bezier spline plugin and now it works perfect with these curves πŸ‘ .
          Kind regards
          • fredo6F Offline
            fredo6
            To create a Sketchup curve out of a sequence of edges, you need a Plugin, as this is (still) not provided by SketchUp in native, even in 2019!
            The most popular plugin is TIG Weld. You have also some others: one by Eneroth3 and also Curvizard.
