    New to DC: topic for my simple questions to the pros
    74 Posts 3 Posters 70.7k Views 3 Watching
    • P
      pcmoor
      you could use the summary to display the data as the "component info" section is not affected.
      I suggest you consider using some ruby scripts with your DCs to help with placement, multiple changes....
      auto-erasing formulas.skp
      • P
        pibuz
        Hi all!
        Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500)
        Do you have any hints for me?
        Thanks in advance as usual!
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • P
          pcmoor
          nearest
          then test if input > nearest
          if so find the next value
          example 1: use a string of values and string functions to get the next
          next largest.skp
          • P
            pibuz
            I was almost there πŸ˜† thanks a lot Phil!
            • P
              pibuz
              Hi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
              Thanks in advance!
              • P
                pibuz
                Hi again! I have a new question for Phil 🀣
                I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO.
                I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that?
                Thanks in advance!
                • P
                  pcmoor
                  Hi Filippo
                  can use nested SUBSTITUTE
                  order is important
                  example attached
                  SUBSTITUTE.skp
                  • P
                    pibuz
                    So cool! Thanks a lot, I couldn't have made it by myself. πŸ’š
                    • P
                      pibuz
                      Hi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
                      Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2".
                      This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion).
                      Con any of you guys recall what was the name of this plugin?
                      Thanks in advance!
                      • P
                        pcmoor
                        Eneroth Decrease Component Number on extension warehouse
                        • P
                          pibuz
                          Wonderful!!! THANKS Phil!
                          • P
                            pibuz
                            Hi again! Happy new year!
                            I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code:
                            mod = Sketchup.active_model # Open model
                            sel = mod.selection # Current selection
                            path = mod.path #current path
                            mypath= File.join(File.dirname(path),'/') #not the model name
                            sel.each do |sel| # you would have to select all components in the model
                            compname = sel.name # each component's definition name
                            thumbnailname = File.join(mypath, compname + '.jpg') # as jpg
                            sel.definition.save_thumbnail thumbnailname
                            The only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance!
                            • P
                              pibuz
                              Hi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
                              Thanks in advance!
                              • P
                                pibuz
                                Hi again!
                                another silly question: is there any way a plugin could select all the dynamic components which share the exact same attribute selections as the selected one?
                                Could be very useful.
                                A searched a lot but could not find any in the internet..
                                Thanks in advance!
                                • 4 / 4
