    New to DC: topic for my simple questions to the pros
    Scheduled Pinned Locked Moved Dynamic Components
    74 Posts 3 Posters 73.3k Views 3 Watching
    • P
      pibuz
      Hi again! I've encontered a critical misfunction, I'm posting this in the hope someone can help me figure out how to dodge this.
      In the file I attach there's a panel. If I copy the panel, select both copies and change the length, both component react correctly BUT the formulas contained in the last 3 top-level attribute rows are deleted, substituted by their value as fixed number.
      What can cause this?
      And secondary: is there a way to apply a certain DC configuration to another DC of the same "family"?
      Thanks in advance!
      EDIT
      Found another user's post showing same issue. Seems to be related to the attribute state set to "User can see". Thanks!
      auto-erasing formulas.zip
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • P
        pcmoor
        you could use the summary to display the data as the "component info" section is not affected.
        I suggest you consider using some ruby scripts with your DCs to help with placement, multiple changes....
        auto-erasing formulas.skp
        • P
          pibuz
          Hi all!
          Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500)
          Do you have any hints for me?
          Thanks in advance as usual!
          • P
            pcmoor
            nearest
            then test if input > nearest
            if so find the next value
            example 1: use a string of values and string functions to get the next
            next largest.skp
            • P
              pibuz
              I was almost there πŸ˜† thanks a lot Phil!
              • P
                pibuz
                Hi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
                Thanks in advance!
                • P
                  pibuz
                  Hi again! I have a new question for Phil 🀣
                  I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO.
                  I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that?
                  Thanks in advance!
                  • P
                    pcmoor
                    Hi Filippo
                    can use nested SUBSTITUTE
                    order is important
                    example attached
                    SUBSTITUTE.skp
                    • P
                      pibuz
                      So cool! Thanks a lot, I couldn't have made it by myself. πŸ’š
                      • P
                        pibuz
                        Hi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
                        Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2".
                        This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion).
                        Con any of you guys recall what was the name of this plugin?
                        Thanks in advance!
                        • P
                          pcmoor
                          Eneroth Decrease Component Number on extension warehouse
                          • P
                            pibuz
                            Wonderful!!! THANKS Phil!
                            • P
                              pibuz
                              Hi again! Happy new year!
                              I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code:
                              mod = Sketchup.active_model # Open model
                              sel = mod.selection # Current selection
                              path = mod.path #current path
                              mypath= File.join(File.dirname(path),'/') #not the model name
                              sel.each do |sel| # you would have to select all components in the model
                              compname = sel.name # each component's definition name
                              thumbnailname = File.join(mypath, compname + '.jpg') # as jpg
                              sel.definition.save_thumbnail thumbnailname
                              The only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance!
                              • P
                                pibuz
                                Hi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
                                Thanks in advance!
                                • P
                                  pibuz
                                  Hi again!
                                  another silly question: is there any way a plugin could select all the dynamic components which share the exact same attribute selections as the selected one?
                                  Could be very useful.
                                  A searched a lot but could not find any in the internet..
                                  Thanks in advance!
                                  • 4 / 4
