    New to DC: topic for my simple questions to the pros
    Scheduled Pinned Locked Moved Dynamic Components
    74 Posts 3 Posters 73.3k Views 3 Watching
    • P
      pibuz
      Hi all!
      Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500)
      Do you have any hints for me?
      Thanks in advance as usual!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • P
        pcmoor
        nearest
        then test if input > nearest
        if so find the next value
        example 1: use a string of values and string functions to get the next
        next largest.skp
        • P
          pibuz
          I was almost there πŸ˜† thanks a lot Phil!
          • P
            pibuz
            Hi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
            Thanks in advance!
            • P
              pibuz
              Hi again! I have a new question for Phil 🀣
              I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO.
              I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that?
              Thanks in advance!
              • P
                pcmoor
                Hi Filippo
                can use nested SUBSTITUTE
                order is important
                example attached
                SUBSTITUTE.skp
                • P
                  pibuz
                  So cool! Thanks a lot, I couldn't have made it by myself. πŸ’š
                  • P
                    pibuz
                    Hi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
                    Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2".
                    This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion).
                    Con any of you guys recall what was the name of this plugin?
                    Thanks in advance!
                    • P
                      pcmoor
                      Eneroth Decrease Component Number on extension warehouse
                      • P
                        pibuz
                        Wonderful!!! THANKS Phil!
                        • P
                          pibuz
                          Hi again! Happy new year!
                          I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code:
                          mod = Sketchup.active_model # Open model
                          sel = mod.selection # Current selection
                          path = mod.path #current path
                          mypath= File.join(File.dirname(path),'/') #not the model name
                          sel.each do |sel| # you would have to select all components in the model
                          compname = sel.name # each component's definition name
                          thumbnailname = File.join(mypath, compname + '.jpg') # as jpg
                          sel.definition.save_thumbnail thumbnailname
                          The only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance!
                          • P
                            pibuz
                            Hi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
                            Thanks in advance!
                            • P
                              pibuz
                              Hi again!
                              another silly question: is there any way a plugin could select all the dynamic components which share the exact same attribute selections as the selected one?
                              Could be very useful.
                              A searched a lot but could not find any in the internet..
                              Thanks in advance!
                              • 4 / 4
