    New to DC: topic for my simple questions to the pros
    74 Posts 3 Posters 65.9k Views 3 Watching
    • P Offline
      pibuz
      Bummer... Thanks a lot by the way!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • P Offline
        pibuz
        Hi again!
        ..I am wondering: is there any way I can make a list option in a DC to be displayed in red?
        • P Offline
          pcmoor
          You can alter the font on component info attributes and labels, not values using syntax as per
          https://help.sketchup.com/en/sketchup/dynamic-components-supported-html-tags
          you can change via formula as per example, so a particular value could set up a warning in the info section
          colors in label and component info.skp
          • P Offline
            pibuz
            Hi Moor! Thank you very much for your support!
            I've encountered another issue: I need to "cut" holes into a cloth sheet. Basically, I decide the cloth dimensions and, based on that, a series of holes must appear for it to be fixed to the surrounding structure. I observed that the "cutting component" works, but its copies do not.
            Is there a way to fix this?
            THANKS A LOT!
            cielino tessuto occhiellato_v3.skp
            • P Offline
              pcmoor
              you basically create a cutting component within another cutting component
              https://sketchucation.com/forums/viewtopic.php?f=180&t=67635&hilit=+hole
              • P Offline
                pibuz
                Thank you very much! After a little hassle I found my way!
                • P Offline
                  pibuz
                  Hi again! I have an issue with the attached dynamic component: I can't figure out why I don't get the lower plane length to be updated if I change the length AFTER the copies are done. Seems like the lemgth parameter doesn't apply to the copies.... Does anyone have an hint or me?
                  cielino v6.skp
                  • P Offline
                    pcmoor
                    to overcome (workaround) this issue you can collect the geometry into another component then reference the current state of the size property
                    When experiencing problems with rotation or sizes< I have found that adding another "shell" isolates and protects the contents from SketchUp making unwanted updates.
                    The encasing and reference to a current value is the basis for creating components that can be swapped so their current size properties are retained. Like a timber beam with a length in say lenx, can be swapped with a steel beam and their lengths match. Of course you would not want this to to happen when you swap a toilet for a basin, which is the behavior that is built into the DC code and what you are experiencing.
                    cielino_fascione coverup (use of current and extra component shell).skp
                    • P Offline
                      pibuz
                      Thanks a lot Moor! I'm going to keep this in mind!
                      • P Offline
                        pibuz
                        Hi to all! I have a small issue regarding materials and custom material libraries, not specifically DCs, but I thought to post here not to add another topic.
                        I am currently trying to save skm materials from the models I'm making, so that it's easier to reuse them in other models. I work with a template which loads some standard materials, say for example a pure 255 white called "white cloth". If I make a component in a new file with another perfect white material named "white plastic" and I import the model into the template model file everything works ok: the second material is added to the home library of materials. If instead I have "saved as" my white plastic material in a custom skm library, whenever I try to paint it to an object which is into the template model it gets automatically substituted by the white cloth material. Is there a way to fix this?
                        • P Offline
                          pibuz
                          Hi again! I want to have to possibility to have the Definition Name of a DC to be displayed in the Options Dialog, so that if I rename a DC I have its correct name on the dialog. Is that possible?
                          • P Offline
                            pcmoor
                            The components instance name is already tied to both the attribute and option dialog, this can be updated on the fly. This works if you do not use the name attribute and only after loading the component.
                            Otherwise the component definition name can be accessed via a ruby script and placed into an attribute value.
                            • P Offline
                              pibuz
                              Thanks! And what would this ruby script be?
                              • P Offline
                                pcmoor
                                see the link to topic
                                https://sketchucation.com/forums/viewtopic.php?f=289&t=71346
                                • P Offline
                                  pibuz
                                  thanks Moor!
                                  Sorry, but maybe I misexplained what I need, I'm attaching an example.
                                  In this case I'd like that if I rename the component to whatever else, I get the new name in the Option dialog title. At the moment, this wont' happen: it keeps titling "elemento da prelevare_shell".
                                  190913_template prelievo da magazzino.skp
                                  • P Offline
                                    pcmoor
                                    you can use the component instance name to give each instance an unique name which is reflected in all the dialog, which is the natural inbuilt way
                                    otherwise set
                                    Name = _name
                                    in the DC then
                                    use a button from the toolbar extension to fire the code snippet to alter the _name attribute, which reads the current definition name, updates the original name to update the option dialog
                                    • P Offline
                                      pibuz
                                      Sorry Moor, I don't understand. In the file I sent you, if I change the Instance name of "elemento da prelevare_shell" NOTHNG CHANGES in any window...
                                      • P Offline
                                        pcmoor
                                        saveas the DC to a folder then bring it into another file, for some reason it does not initially work within its created file, after that, should work, regardless of the number of changes, the references are still maintained
                                        • P Offline
                                          pibuz
                                          OH BIG THANKS! I WAS MISSING THE FACT THAT IT DOESN'T WOTK ON THE ORIGINAL FILE!
                                          • P Offline
                                            pibuz
                                            Hi again! is there a way I can LOCK the rotation of a DC along specific axis'?
                                            I have a panel which I don't want users to be able to use as ceiling, so I only want it to be rotateable along its blue axis
                                            • 2 / 4
