    New to DC: topic for my simple questions to the pros
    Scheduled Pinned Locked Moved Dynamic Components
    74 Posts 3 Posters 73.3k Views 3 Watching
    • P
      pibuz
      hi again! Is there a way to insert a formula depending on the fact the result of an operation is an integer number? something like: IF LENX/LENY IS AN INTEGER NUMBER THEN WRITE 1,0.
      I know how to use the If function, but i don't know if there's a way to check an integer number...
      Thanks a lot!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • P
        pcmoor
        you can check for the remainder and if none then must be an integer
        =if(lenx/leny - int(lenx/leny),0,1)
        • P
          pibuz
          Thank you sir! Gonna test asap!!!
          • P
            pibuz
            Hi again! i have a new small issue: I have a basic Dynamic Component which can be edited in its inner parts. I just want the dynamic component to report the size of its bounding box, depending of the things I put inside. In the component attributes, window the LenX LenY LenZ parameters correctly update when I add/move things inside the DC, but if I link to those values three different addributes ("length"=LenX, "width"=LenY, "height"=LenZ) I have to REDRAW the components if I want the values to update. Is there a way to update automatically?
            THANK YOU IN ADVANCE AS SUSUAL!
            • P
              pcmoor
              Most likely you need to do a redraw, you can set a short cut key to it provided you have a component selected.
              Another method is to set a ruby script to a button
              https://forums.sketchup.com/t/redraw-all-dynamic-components/77512
              You probably need to use some ruby to overcome the shortcomings of DCs
              • P
                pibuz
                Bummer... Thanks a lot by the way!
                • P
                  pibuz
                  Hi again!
                  ..I am wondering: is there any way I can make a list option in a DC to be displayed in red?
                  • P
                    pcmoor
                    You can alter the font on component info attributes and labels, not values using syntax as per
                    https://help.sketchup.com/en/sketchup/dynamic-components-supported-html-tags
                    you can change via formula as per example, so a particular value could set up a warning in the info section
                    colors in label and component info.skp
                    • P
                      pibuz
                      Hi Moor! Thank you very much for your support!
                      I've encountered another issue: I need to "cut" holes into a cloth sheet. Basically, I decide the cloth dimensions and, based on that, a series of holes must appear for it to be fixed to the surrounding structure. I observed that the "cutting component" works, but its copies do not.
                      Is there a way to fix this?
                      THANKS A LOT!
                      cielino tessuto occhiellato_v3.skp
                      • P
                        pcmoor
                        you basically create a cutting component within another cutting component
                        https://sketchucation.com/forums/viewtopic.php?f=180&t=67635&hilit=+hole
                        • P
                          pibuz
                          Thank you very much! After a little hassle I found my way!
                          • P
                            pibuz
                            Hi again! I have an issue with the attached dynamic component: I can't figure out why I don't get the lower plane length to be updated if I change the length AFTER the copies are done. Seems like the lemgth parameter doesn't apply to the copies.... Does anyone have an hint or me?
                            cielino v6.skp
                            • P
                              pcmoor
                              to overcome (workaround) this issue you can collect the geometry into another component then reference the current state of the size property
                              When experiencing problems with rotation or sizes< I have found that adding another "shell" isolates and protects the contents from SketchUp making unwanted updates.
                              The encasing and reference to a current value is the basis for creating components that can be swapped so their current size properties are retained. Like a timber beam with a length in say lenx, can be swapped with a steel beam and their lengths match. Of course you would not want this to to happen when you swap a toilet for a basin, which is the behavior that is built into the DC code and what you are experiencing.
                              cielino_fascione coverup (use of current and extra component shell).skp
                              • P
                                pibuz
                                Thanks a lot Moor! I'm going to keep this in mind!
                                • P
                                  pibuz
                                  Hi to all! I have a small issue regarding materials and custom material libraries, not specifically DCs, but I thought to post here not to add another topic.
                                  I am currently trying to save skm materials from the models I'm making, so that it's easier to reuse them in other models. I work with a template which loads some standard materials, say for example a pure 255 white called "white cloth". If I make a component in a new file with another perfect white material named "white plastic" and I import the model into the template model file everything works ok: the second material is added to the home library of materials. If instead I have "saved as" my white plastic material in a custom skm library, whenever I try to paint it to an object which is into the template model it gets automatically substituted by the white cloth material. Is there a way to fix this?
                                  • P
                                    pibuz
                                    Hi again! I want to have to possibility to have the Definition Name of a DC to be displayed in the Options Dialog, so that if I rename a DC I have its correct name on the dialog. Is that possible?
                                    • P
                                      pcmoor
                                      The components instance name is already tied to both the attribute and option dialog, this can be updated on the fly. This works if you do not use the name attribute and only after loading the component.
                                      Otherwise the component definition name can be accessed via a ruby script and placed into an attribute value.
                                      • P
                                        pibuz
                                        Thanks! And what would this ruby script be?
                                        • P
                                          pcmoor
                                          see the link to topic
                                          https://sketchucation.com/forums/viewtopic.php?f=289&t=71346
                                          • P
                                            pibuz
                                            thanks Moor!
                                            Sorry, but maybe I misexplained what I need, I'm attaching an example.
                                            In this case I'd like that if I rename the component to whatever else, I get the new name in the Option dialog title. At the moment, this wont' happen: it keeps titling "elemento da prelevare_shell".
                                            190913_template prelievo da magazzino.skp
                                            • 2 / 4
