    Pointing at sequence hides Animator tools; bug?
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    9 Posts 2 Posters 7.7k Views 2 Watching
      DaBouncer
      I'm experiencing a strange behavior in Animator 2.3c.
      When I point at sequence some of the tools are hidden and sometimes all of them disappears completely; then if I try to "restart" Animator by clicking any of the icons in the toolbar, Windows throws a warning sound; I have to quit Sketchup and once closed the "Exit temporary to Sketchup" windows appears...
      Rgds,
      Petter
      • fredo6F Offline
        fredo6
        I think there is an error.
        Would you mind opening the Ruby Console before you click on the icons and report what you see there (just copy the text and paste it in your post).
        Fredo
          DaBouncer
          Thanks Fredo, I get this:
          Error: #<NoMethodError: undefined method x' for nil:NilClass> c:/users/****/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6pathmanager.rbe:605:in draw_trace_effective_curve'
          c:/users//appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6compmanager.rbe:1844:in movement_trace_draw' c:/users/****/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe:3909:in sequence_movement_draw_trace'
          c:/users/
          /appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe:3890:in sequence_draw_trace' c:/users/****/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatorclipsequencer.rbe:4721:in drawing_trace_element'
          c:/users/****/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatorclipsequencer.rbe:4687:in draw' c:/users/****/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:1523:in draw'
          • fredo6F Offline
            fredo6
            This is fixed normally with LibFredo6 8.6p.
            Thanks to advise
            Fredo
              DaBouncer
              That sorted it, thanx!
              Superb extension for Sketchup, keep up the good work ('',)
                DaBouncer
                Seems I pulled the trigger a bit to fast on this one; the issue remains with LibFredo6 8.6p
                Note the status in the bottom left of this image; could that be relevant here?
                https://i.ibb.co/pxDR6hY/2018-12-07-1.png
                • fredo6F Offline
                  fredo6
                  Same thing. Could you open the Ruby Console.
                  Would be helpful that I get your model too.
                  Fredo
                    DaBouncer
                    The issue does not happen all the time so I have not been able to capture anything in Ruby Console yet. I've sendt the two files I'm currently working on in a PM.
                      DaBouncer
                      So this has happened a few times after first rendering a sequence and changing view to render another:
                      Error: #<NoMethodError: undefined method include?' for nil:NilClass> c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:668:in format_html_all'
                      c:/users//appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:649:in prepare_html' c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:418:in dialog_create'
                      c:/users/
                      /appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:361:in dialog_invoke' c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:2205:in movie_dialog'
                      c:/users//appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:2175:in movie_clip_generation' c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatorpalette.rbe:819:in block in palette_clip_name_duration_video'
                      c:/users/
                      /appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call' c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in execute_button'
                      c:/users//appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3765:in onLButtonUp' c:/users/******/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:91:in onLButtonUp'
                      c:/users/
                      /appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_animator/animatortool.rbe:1275:in `onLButtonUp'
                      https://i.ibb.co/jDpD82r/2018-12-19.png
                      Same as before; when I quit Sketchup the "Exit temporary to Sketchup" window have been hiding in the background.
