    Curviloft default settings
    17 Posts 4 Posters 9.2k Views 4 Watching
    • P Offline
      pipingguy
      When using "loft junctions between surfaces based on spline curves", can the various choices in each of the tool palette's panels be set as user-defined defaults? For example, 95% of the time I use 'junction by orthogonal elliptical curves' in the Spline Method panel. Also - is there a way to force the generated geometry's edges to follow a user's pre-defined degree of softness? Just trying to save some click time.
      • BoxB Offline
        Go/Tools/Fredo6 Collection/Curviloft/Default parameters...
        • P Offline
          pipingguy
          In the "Default Parameters: Curviloft" thing being suggested, I just tried unchecking all boxes associated with quads > saved changes > re-launched skp - but still getting same old softened edge results.
          • fredo6F Offline
            fredo6
            Note that Curviloft keeps the state of the latest parameters used, even across Sketchup sessions. In practice, this is more flexible than to use default parameters.
            And, for softening edges of the generated surfaces, unfortunately, there is NO way via the Sketchup API to specify the smoothing angle (unlike what you can do in the Sketchup GUI).
            Fredo
            • P Offline
              pipingguy
              I wish it would retain settings as you describe. But it always reverts back to 'smooth junction by a single cubic bezier curve' every time I activate the tool within the same session. Could outdated script be the issue? see attached pdf.
              revert.pdf
              • fredo6F Offline
                fredo6
                Definitely.
                I even wonder how your old versions still work.
                For the future, you'll better keep my plugin up to date, even if you run an old version of Sketchup.
                The preservation of Curviloft parameters was introduced earlier this year.
                • P Offline
                  pipingguy
                  OK.....I updated my Fredo files. However, I am still unable to preserve the parameter 'junction by orthogonal elliptical curves' as a user-defined default. I am not really seeing anything in the parameters dialogue box that would be applicable. See attached images.
                  • fredo6F Offline
                    fredo6
                    You have to go to the Default Parameters dialog box of Curviloft
                    menu is: Tools > Fredo6 Collection > Curviloft > Default Parameters.
                    • P Offline
                      pipingguy
                      that works! thanks!
                      • P Offline
                        pipingguy
                        Monsieur Fredo (or anyone)- how best to extrude the attached tapered volute?
                        tapered volute.skp
                        • fredo6F Offline
                          fredo6
                          Curviloft does not like that the two circle are coplanar.
                          I don't have time to investigate and troubleshoot at the moment.
                          So I suggest you look at Spirix, which is specialized in creating spiraling shapes.
                          Fredo
                          • P Offline
                            pipingguy
                            That's OK. I will just continue doing it in 4 pieces, then 'welding' them together.
                            • P Offline
                              pipingguy
                              From what i can see, there is no such thing as default parameters for Fredo6:Bezier Spline - correct?
                              • fredo6F Offline
                                fredo6
                                NO, but it should keep the parameters to their last value when you exit BezierSpline.
                                • P Offline
                                  pipingguy
                                  Not that I can see.
                                    memaridrue81
                                    hi ,
                                    i really dont now what happned but my curviloft settinngs is so diffrent from the ususal settings I see in you tube.
                                    • fredo6F Offline
                                      fredo6
                                      @memaridrue81 said:
                                      hi ,
                                      The video may be old.
                                      Anyway, could you be more explicit et advise whether there is a problem. Thanks.
