    Curviloft default settings
    17 Posts 4 Posters 9.0k Views 4 Watching
    • fredo6F Offline
      @pipingguy said:
      OK.....I updated my Fredo files. However, I am still unable to preserve the parameter 'junction by orthogonal elliptical curves' as a user-defined default. I am not really seeing anything in the parameters dialogue box that would be applicable. See attached images.
      You have to go to the Default Parameters dialog box of Curviloft
      menu is: Tools > Fredo6 Collection > Curviloft > Default Parameters.
        pipingguy
        that works! thanks!
          pipingguy
          Monsieur Fredo (or anyone)- how best to extrude the attached tapered volute?
          tapered volute.skp
          • fredo6F Offline
            Curviloft does not like that the two circle are coplanar.
            I don't have time to investigate and troubleshoot at the moment.
            So I suggest you look at Spirix, which is specialized in creating spiraling shapes.
              pipingguy
              That's OK. I will just continue doing it in 4 pieces, then 'welding' them together.
                pipingguy
                From what i can see, there is no such thing as default parameters for Fredo6:Bezier Spline - correct?
                • fredo6F Offline
                  NO, but it should keep the parameters to their last value when you exit BezierSpline.
                    pipingguy
                    Not that I can see.
                      memaridrue81
                      hi ,
                      i really dont now what happned but my curviloft settinngs is so diffrent from the ususal settings I see in you tube.
                      • fredo6F Offline
                        @memaridrue81 said:
                        hi ,
                        The video may be old.
                        Anyway, could you be more explicit et advise whether there is a problem. Thanks.
