    Curviloft default settings
    17 Posts 4 Posters 9.2k Views 4 Watching
    • fredo6F Offline
      @pipingguy said:
      Could outdated script be the issue? see attached pdf.
      Definitely.
      I even wonder how your old versions still work.
      For the future, you'll better keep my plugin up to date, even if you run an old version of Sketchup.
      The preservation of Curviloft parameters was introduced earlier this year.
        pipingguy
        OK.....I updated my Fredo files. However, I am still unable to preserve the parameter 'junction by orthogonal elliptical curves' as a user-defined default. I am not really seeing anything in the parameters dialogue box that would be applicable. See attached images.
        • fredo6F Offline
          You have to go to the Default Parameters dialog box of Curviloft
          menu is: Tools > Fredo6 Collection > Curviloft > Default Parameters.
            pipingguy
            that works! thanks!
              pipingguy
              Monsieur Fredo (or anyone)- how best to extrude the attached tapered volute?
              tapered volute.skp
              • fredo6F Offline
                Curviloft does not like that the two circle are coplanar.
                I don't have time to investigate and troubleshoot at the moment.
                So I suggest you look at Spirix, which is specialized in creating spiraling shapes.
                  pipingguy
                  That's OK. I will just continue doing it in 4 pieces, then 'welding' them together.
                    pipingguy
                    From what i can see, there is no such thing as default parameters for Fredo6:Bezier Spline - correct?
                    • fredo6F Offline
                      NO, but it should keep the parameters to their last value when you exit BezierSpline.
                        pipingguy
                        Not that I can see.
                          memaridrue81
                          hi ,
                          i really dont now what happned but my curviloft settinngs is so diffrent from the ususal settings I see in you tube.
                          • fredo6F Offline
                            @memaridrue81 said:
                            hi ,
                            The video may be old.
                            Anyway, could you be more explicit et advise whether there is a problem. Thanks.
