    Tool for non-linear warping/bulging of objects?
    extensions
    6 Posts 5 Posters 3.2k Views 5 Watching
      csolar
      Anyone know of a tool that will let me distort an object in a non-linear way? For instance, I'd like to be able to take something like a straight-sided cylinder and turn it into bulging barrel shape. I've done some looking but haven't seen anything -- suggestions welcome!
        rv1974
        FFD (although semi-working)
          csolar
          Thanks, that looks like the kind of thing I'm after. Will check it out.
          • L Online
            sculpt?
            • pbacotP Offline
              Vertex tools would do what you describe and similar things easily. You need to add points by duplicating rings along the cylinder.
                charevir56
                Jitter probably works for you
                https://sketchucation.com/forums/viewtopic.php?f=323&t=64554&p=592146#p592146
