    [looking] components to groups after DWG import
    17 Posts 6 Posters 2.6k Views 6 Watching
    • pbacotP Offline
      I am looking for a plugin to take all selected components and turn them into groups--and also remove those components from the library.
      When importing geometry from dwg every group (block) from CAD becomes a component. I have no use for that in SU. I only want my drawn work to be components.
      Also, ideally all geometry should be on Layer0 (and the groups stay on the imported layers. We have the "default layer geometry" plugin but it can be very slow. Since this is how SU is supposed to work, why does DWG import put the geometry on the wrong layers?
      • CadFatherC Offline
        CadFather
        try this (it's only the comps conversion part)
        @m = Sketchup.active_model    ;   @s = @m.selection   ;   @e = @m.entities
        	@m.start_operation('COMPS TO GROUPS', true)
                if @s.empty?
                UI.messagebox('No Component selected.')
                else
        				sel = []
        			@s.to_a.each{|obj|
        				next unless obj.is_a?(Sketchup;;ComponentInstance)
                         g = nil
        				 g = @e.add_group obj
        				 g.name = obj.definition.name
        				 sel << g
        				 obj.explode  }
        			 @s.add sel
            @m.commit_operation
          After running Max's script you could use TIG's Purge All to purge the components from the In Model collection. Set up a keyboard short cut for each.
          • pbacotP Offline
            Excellent I shall try that out! I didn't expect a custom plugin just like that. Very nice of you! Thanks. Dave, the "purge all" should work fine. If it works I'll be using it forever. Although I don't do this everyday, every time I need to do it I wish for something like this.
              Peter, I would highly suggest that you make it a habit to either run TIG's Purge All or at least Purge Unused from ModelInfo>Statistics at least periodically while you are modeling. It'll help to keep your model cleaner and easier to work with. I prefer TIG's Purge All because it gives me a quick report of how much was purged.
              • pbacotP Offline
                Dave, I do the purge, but I should more often! Thanks Dave and CADfather!
                • Didier BurD Offline
                  Didier Bur
                  @pbacot,
                  In a few days you can also download my latest tool "Purge Tool" on the EW πŸ˜‰
                  It's a cleanup utility that mimics the Autocad Purge command.
                  DB
                  • jujuJ Offline
                    juju
                    It looks like Didier is pumping out some extensions...
                    • pbacotP Offline
                      Thank Didier. Look forward to seeing that!
                      • pbacotP Offline
                        >         if @s.empty?
                        >         else
                        > 				sel = []
                        > 			@s.to_a.each{|obj|
                        >                  g = nil
                        > 				 sel << g
                        > 				 obj.explode  }
                        > 			 @s.add sel
                        >         end
                        >     @m.commit_operation
                        This works really well for selected components but the nested components remain. The crux is that I create CAD files with many groups, and while they act as groups (not components) in CAD they become components in SketchUp (with inexplicable names) and fill up the library. they are generally nested. So the extra work involved is actually dealing with the nested components.
                        • jujuJ Offline
                          juju
                          @didier bur said:
                          @pbacot,
                          [attachment=1:lj75knum]<!-- ia1 -->purgetool_icon 60x60.png<!-- ia1 -->[/attachment:lj75knum]
                          [attachment=0:lj75knum]<!-- ia0 -->Main dialog.jpg<!-- ia0 -->[/attachment:lj75knum]
                          [attachment=3:lj75knum]<!-- ia3 -->purge component.jpg<!-- ia3 -->[/attachment:lj75knum]
                          [attachment=2:lj75knum]<!-- ia2 -->report.jpg<!-- ia2 -->[/attachment:lj75knum]
                          Aaaah, on EW finally, except I can't download it for the some or other strange reason.
                            Why not? What happens when you try?
                            I installed just now and it worked fine although it indicates it hasn't been signed. That won't prevent it from working unless permissions are set to disallow unsigned extensions.
                            • jujuJ Offline
                              juju
                              You hit Download and the little wheel comes out with Please Wait but nothing happens.
                              Tried this now again and was able to download, thanks.
                              • jujuJ Offline
                                juju
                                For those of you that have installed Purge Tool and may not be sure where it is launched from, it can be found under the Tools menu.
                                • OxerO Offline
                                  Oxer
                                  There is a plugin to convert components to groups, here is Make_Components
                                  http://www.oxervision.blogspot.com/
                                  • pbacotP Offline
                                    Thanks, I'll try it!
                                    • pbacotP Offline
                                      So far nothing quite does what I need. I need this to work on all all selected components, nested as well.
