    Ruby Operation left Open
    4 Posts 2 Posters 6.2k Views 2 Watching
    • medeekM
      medeek
      I've had this bug in my plugin for a while. My code is:
      # Get handles to our model and the Entities collection it contains.
      @model1 = Sketchup.active_model
      entities = @model1.entities
      if @Trusstype == "King Post"
        @Model_operation = 'Draw King Post Truss'
        draw_status = @model1.start_operation(@Model_operation)
        ....  lots of code here ....
      .... more code here ....
      draw_status = @model1.commit_operation
      Everything looks good but I keep getting this error:
      warning; Ruby operation left open; "Draw King Post Truss"
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • TIGT
        It's always best to add a second argument , true to the .start_operation.
        Also ensure there's nothing in your code that skips out before you get to do the .commit_operation at the end.
        If you do have some methods with code that might bale-out ensure that any ' rescue' also includes the .commit_operation and a return, alternatively use .abort_operation and a return so nothing is done at all...
        • medeekM
          medeek
          I think this may be the hint that I need. For some reason it never occurred to me that the program might be somehow terminating before it got to the final commit command, duh. Looking at it again now.
          design.medeek.com
          • TIGT
            Also remember that your code as we can see it ALWAYS does a commit - even if there was never an operation started.
            But since we only see some of your code it's unclear if there's always an operation to be committed !
            One way round that is initially to set **@**draw_status = false, then within the 'tests' use **@**draw_status = @model1.start_operation(@Model_operation, true) e.g. in if @Trusstype...
            Always remembering to set in each 'test':
            and then in your unshown code, for each commit you need to use:
            draw_status = @model1.commit_operation if **@**draw_status
            So you don't commit anything unless an operation is been started...
