Ruby Operation left Open
4 Posts 2 Posters 6.0k Views 2 Watching
    medeek
    I've had this bug in my plugin for a while. My code is:
    # Get handles to our model and the Entities collection it contains.
    @model1 = Sketchup.active_model
    entities = @model1.entities
    if @Trusstype == "King Post"
      @Model_operation = 'Draw King Post Truss'
      draw_status = @model1.start_operation(@Model_operation)
      ....  lots of code here ....
    .... more code here ....
    draw_status = @model1.commit_operation
    Everything looks good but I keep getting this error:
    warning; Ruby operation left open; "Draw King Post Truss"
    Nathaniel P. Wilkerson PE
    Medeek Engineering Inc
    design.medeek.com
      It's always best to add a second argument , true to the .start_operation.
      Also ensure there's nothing in your code that skips out before you get to do the .commit_operation at the end.
      If you do have some methods with code that might bale-out ensure that any ' rescue' also includes the .commit_operation and a return, alternatively use .abort_operation and a return so nothing is done at all...
        medeek
        I think this may be the hint that I need. For some reason it never occurred to me that the program might be somehow terminating before it got to the final commit command, duh. Looking at it again now.
        design.medeek.com
          Also remember that your code as we can see it ALWAYS does a commit - even if there was never an operation started.
          But since we only see some of your code it's unclear if there's always an operation to be committed !
          One way round that is initially to set **@**draw_status = false, then within the 'tests' use **@**draw_status = @model1.start_operation(@Model_operation, true) e.g. in if @Trusstype...
          Always remembering to set in each 'test':
          and then in your unshown code, for each commit you need to use:
          draw_status = @model1.commit_operation if **@**draw_status
          So you don't commit anything unless an operation is been started...
