    Problem with BezierSpline Curves on Macbook Pro
    6 Posts 3 Posters 3.8k Views 3 Watching
      spdbl
      Problem with BezierSpline Curves.mov
      I installed Frodo's BezierSpline Curves and find some of them work and some don't. A short movie outlining the problem is attached. I tried switching styles, but the same thing happens no matter which style I use.
      I'm on a 2011 Macbook Pro running Sierra 10.12.6, using Sketchup Make 2017.
      Thanks in advance for any suggestions.
      • fredo6F Offline
        fredo6
        @spdbl said:
        [attachment=0:33o7k5l2]<!-- ia0 -->Problem with BezierSpline Curves.mov<!-- ia0 -->[/attachment:33o7k5l2]
        Clear. Could you please open the Ruby Console while trying Polyline Arc Corner or Uniform B-Spline.
        Normally, for these tow curves, you are prompted for a parameter, and obviously the dialog box does not show up.
        Fredo
          spdbl
          @fredo6 said:
          @spdbl said:
          [attachment=0:2ukfzxoj]<!-- ia0 -->Problem with BezierSpline Curves.mov<!-- ia0 -->[/attachment:2ukfzxoj]
          Fredo
          Thanks for your reply, Fredo. My apologies for calling you Frodo - too much Tolkien.
          I tried again with the Ruby console open, and a short video is attached. I am heading for the country, and will be offline for a few days, but will check out the forum when I get back.
          Thanks again,
          Jim
          text from ruby dialogue below:
          true
          Error: #<NameError: uninitialized constant BZ__BSplineU::Traductor>
          /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/BZ__BSplineU.rb:73:in bz_ask_extras' /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
          /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:508:in activate'
          /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2063:in select_tool' /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2063:in menu_creation_tool'
          /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2452:in block (2 levels) in load_all_menus' SketchUp:1:in call'
          Error: #<NoMethodError: undefined method >' for nil:NilClass> /Users/jamessrobertson/Library/Application Support/SketchUp 2017/SketchUp/Plugins/bezierspline/BZ__BSplineU.rb:112:in curve'
          • fredo6F Offline
            fredo6
            @spbdl,
            Oop! For got one file in the packaging.
            Maybe, the best is that you install LibFredo6.
            Otherwise, just wait for me to publish an update to BezierSpline
            Fredo
              spdbl
              @fredo6 said:
              @spbdl,
              Fredo
              Hello again,
              I installed the library and everything is working as it should. thanks again. I was using it to draw out the parts to laminate the curved mouldings for this sauna project, and it came in very handy.
                jpreischel
                YES! Thank you!
