    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    440 Posts 152 Posters 597.5k Views 150 Watching
      TDahl
      The Extension Store plugin doesn't work for me (I only tried it for the very first time a week or so ago). I have SketchuCation Extension Store v4.2.3 which is apparently the latest. I have been in contact with TIG about the unzip errors that I'm experiencing, so far unresolved. Therefore, I'm downloading the SketchuCation-hosted plugin RBZ files and then using the native SKetchUp Extension Manager window to install SketchuCation-hosted extensions.
      Just now I updated LibFredo6 from 12.4a to 12.5a, but the didn't help to make RoundCorner work (see traceback below).
      I tried bringing up the FredoCorner UI (even though the license dialog can't be displayed due to the error listed earlier), and the UI does appear. Yay. πŸ˜„ Maybe in 30 days the FredoCorner UI will shut itself off and then the inability to enter a license would be a killer, but for the next month I suppose I'm in business with FredoCorner instead of RoundCorner.
      Here is the traceback when trying to do much of anything with RoundCorner (with SKetchUp 2018, macOS 12.4.6):
      Error: #<LoadError: dlopen(/Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9): no suitable image found. Did find:
      /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
      /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle: cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/Tom/Library/Application Support/SketchUp 2018/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
      /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54:in require' /Applications/SketchUp 2018/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54:in require'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:156:in load_binary' /users/tom/library/application support/sketchup 2018/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:71:in dynamic_token'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1688:in tem_context' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1656:in tem_launcher'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:81:in launch_action' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:96:in block in startup'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1407:in call' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1407:in command_invoke'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1388:in block (2 levels) in build_config_commands' /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in call'
      /users/tom/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command' SketchUp:1:in call'
      • fredo6F Offline
        fredo6
        Unfortunately, you need the ExtensionStore working to validate licenses. You can still install the RBZ by manual copy / unzip or via the Extension Manager, but the installation of Sketchucation ExtensionStore must be OK.
          Tolotos von Halut
          Hello Fredo,
          since longer I use some of your plugins, "Fredo Corner" with a pruchased licence.
          Now, yesterday all the others required a licence. Well, no problem I thought and purchased the 8 Licence bundle and tried to install them. Failed due to old version of sketchup tools, so I installed the recent one and all worked fine.
          This morning I tried to use the software, but each of the plugins only worked for one time, from the second on I was asked to validate the licences 😞
          I think it is because I do not have internet access all the time. I just connected the computer to validate the licence. That always worked with my old licence from Fredo Corner since long, without Internet access.
          What shall I do now? I can't have internet all the time, so I need the licence once validated to work without Internet.
          The way it is now the 40$ where not only wasted, even Fredo Corner does not work anymore.
          Regards
          Stefan
            Tolotos von Halut
            Well, it seems I found a solution.
            It looks that the Sketchup Tool Plugin in the old version only checked while validating if the licence is correct. The new version seems to want to check this every single time a plugin is used.
            I just tried to delete the new Sketchup Tools and reinstalled the old version (4.0.0).
            The plugins are still validated and I get no further questions to validate again, all works for the moment. So if this also remains in 30 days I quess that was the solution.
            Fortunately the old Sketchup Tools does its work without complaining any incompatibility.
            Best regards
            Stefan
              It's not good practice to run older releases of Sketchucation Tools. You may encounter many issues/errors going forward on older builds of Sketchucation Tools.
                Tolotos von Halut
                Well, you surely are right, but what else can I do?
                Staying online all time unfortunately is no option, although that of course would be THE right way.
                Best regards
                Stefan
                • PepetrucciP Offline
                  Pepetrucci
                  @s2eunha said:
                  Hi !
                  All 3 seats of my license are in use. But I can't release the license because I've formatted my computer before. I tried it with that computer, but it failed because the system information was different. The license recognizes it as another computer.
                  Can you initialize the license seats?
                  • License ID: 20166
                  I'm having a similar issue. Did you find a way to release the license? I have it activated on 2 pc but the license info says that i have all 3 seats active, is there a way to release one seat if you have not access to that pc anymore?
                  • N Offline
                    Nattias
                    I got all my 3 seat of Fredo Corner looked and have tried everything to release them 😐
                    My problem is that I get the same info on all my computers witch don't give me any opportunity to release any licens.
                    Sketchucation tool are updated on all computers
                    The computers I use are:
                    1, Imac for Cad and Sketches
                    2, MacBook Pro when traveling
                    3, PC for renderings
                    Any possibility to realize all of them from your side so I can install again on my Imac?
                    Can't work without Fredo Corner:)
                      Make sure you have the latest release of Sketchucation Tools v4.2.5 installed.
                      Restart SketchUp and use the SCF Global Status dialog to choose and release...
                      https://i.imgur.com/TNvokTu.png
                      • K Offline
                        kellyverschoore
                        hi, i have a problem, i get "catena pursue", i dont know what to do... can you help please?
                        • fredo6F Offline
                          fredo6
                          This is related to the shape you are trying to round over, usually when it is complex or the offset is smaller than the smallest edge. Difficult to help without having the model
                            mimom
                            Hello, plz help me Im trying to purchase the bundle as my whole work is on hold now because the plugins are expired, I have tried to purchase the bundle 4 times now in the past 48 hrs nothing is happening, when I go to the card payment page I put the card information and everything when i click pay now , the page refresh and thats it nothing happens ! no transaction no email nothing ! plz reply ASAP.( im already signed up as a free member in sketchucation, I have installed the latest ssketchucation plugin to sketchup,did everything it is asked for yet the payment page is broken for some reason
                              tpghks874
                              how can i solve this problom??
                                F09 shows a mismatch between the Extension's name and the license you are trying to use.
                                Perhaps it's Fredo's RoundCorner versus his FredoCorner - which are two different extensions, and which each have their own license...
                                  Dgx1
                                  Hello.
                                  I've been getting a error message " To continue using the extension fredo corner, please upgrade to the latest version of Sketchucation Extension Store" which I am on per extension manager. also checked the license and Lib 6. all good. any thoughts whats up ?
                                  • fredo6F Offline
                                    fredo6
                                    @dgx1 said:
                                    Hello.
                                    Could you show me a screenshot of the License Dialog box?
                                    or type in the Ruby console: SCFLicense.visual_version
                                    Which version of LibFredo6 do you have?
                                      Dgx1
                                      License Dialog.jpgLibFredo 6.jpgHey Fredo , see attached screenshots as requested please. And Thank you.
                                        Your SCF Licensing is not the latest. It should be 5.7a - 51
                                        https://i.imgur.com/RdGTjnd.png
                                        Not sure why v.4.2.9 of Sketchucation Tools did not update your license binaries but you are not using the latest. Try removing sketchucation.rb and the sketchucation folder from your plugins folder and doing a fresh install.
                                          Dgx1
                                          Thanks Rich. That worked. Back to Rounding corners the easy way.
                                          • K Offline
                                            kiwi7379
                                            I have issues using my FredoCorner too...
                                            I purchased the FredoCorner in December 2021, it worked for a while and it stopped working and I keep getting this message no matter how many times I have re-downloaded the SketchUcation Extension Store. Can someone help?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 21
                                            • 22
                                            • 15 / 22
