    [partially self answered] Apparition tools then select ?
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    2 Posts 2 Posters 9.2k Views 2 Watching
      durandp
      Congrats for this great tool !
      Awsome ...
      My question :
      I have an object,
      I add a new Movement,
      I select my object, then the Apparition tool
      1 check Disappear
      everything works fine !
      How do I select the 'disappeared' object, for example to add a Translation to it ?
      If I add another/new Movment, no way to click on the object (it has disappeared, as expected), I can't select it
      --> solution I found :
      not use the "save sequence then exit" button,
      but instead use "save sequence and create another sequence to same selection"
      BTW : the initial goal, select a disappeared object, is still not solved by me πŸ˜„
      and sorry for my english, i'm french !
      • fredo6F Offline
        fredo6
        Good point.
        I'll address the issue of disappeared object.
        Fredo
