⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
Select object and isolate?
Is there a command or plugin to isolate an object is Sketchup similar to Rhino's isolate command?
It seems like a simple plugin to build.
Select object/s> Hide all unslected.Edit: Found "Select n Isolate plugin but it apparently dosen't work with 2018. Any ruby mavens able to fix that?
See if VisTools will do the trick for you.
Or, place the building you want to isolate on a different layer.
