    Select object and isolate?
    5 Posts 4 Posters 6.4k Views 4 Watching
    • C
      CalypsoArt
      Is there a command or plugin to isolate an object is Sketchup similar to Rhino's isolate command?
      It seems like a simple plugin to build.
      Select object/s> Hide all unslected.
      Edit: Found "Select n Isolate plugin but it apparently dosen't work with 2018. Any ruby mavens able to fix that?
      • jujuJ
        juju
        See if VisTools will do the trick for you.
        • C
          CalypsoArt
          Seem to be the answer. Thanks
            Or, place the building you want to isolate on a different layer.
              agrazdi
              Smustard has it. and it is free
