    Modern airship
    21 Posts 3 Posters 10.5k Views 3 Watching
    • Bryan KB Offline
      This is inspired by a new Syd Mead illustration I saw this week as well as an old design I made 35 years ago
      First, the engine pods. I learned a new trick making the blades. It will be pretty obvious to you old masters, but I wasn't sure it would work.
      And I actually got the Followme Tool to work right for a change. I don't why I have so much trouble with it.
      • Bryan KB Offline
        Another view.
        • Bryan KB Offline
          Rough out of main hull gas bag.
          • Bryan KB Offline
            Rough out of cabins and holds.
              Great result in a difficult topic, have you considered a cabin inside the main fuselage? I think there is a market for this type of aircraft flown at very high altitude as phone and internet communication servers. They could also be used for mapping and lidar purposes. etc et al. A render of this beauty over high cloud and mountains would be about perfect.
              • Bryan KB Offline
                Rough out of the bridge.
                • Bryan KB Offline
                  Bridge imported back into main model.
                  • Bryan KB Offline
                    Bridge updated and control surfaces added.
                    • Bryan KB Offline
                      Top view.
                      • Bryan KB Offline
                        Engines roughed into place.
                        • Bryan KB Offline
                          Forward lounges and penthouse suites.
                          • Bryan KB Offline
                            Thanks Mike.
                            Yes, the main cabins and holds do extend into the gas bag. I'll post a see-through showing that. Good suggestion. Thanks.
                              Nice work Bryan πŸ‘ How did you create the main fuselage, what tool?
                              • Bryan KB Offline
                                Thanks!
                                I used Curviloft. I first created one quarter using the arc tool, then divided that into three sections and then used Curviloft and turned it into a component.
                                • Bryan KB Offline
                                  Here is an xray view showing the cabins extending in the main hull and also the lines used to create the hull that are the initial anchor/guidelines for Curviloft.
                                  I will not be making any interior details at this time. The airship is just part of a larger scene I will be making.
                                  • Bryan KB Offline
                                    Updates.
                                    • Bryan KB Offline
                                      A close up. Look close and you can the SketchUp man for scale.
                                      • Bryan KB Offline
                                        Bridge update. This will be about all the detail I'll add to the bridge at this time.
                                        The box hanging from the ceiling are long range sensors, but not the only ones.
                                        • Bryan KB Offline
                                          A ground view.
                                          • Bryan KB Offline
                                            Lateral thrusters added.
                                            • 1 / 2
