    Modern airship
    21 Posts 3 Posters 11.1k Views 3 Watching
    • Bryan KB
      Another view.
      • Bryan KB
        Rough out of main hull gas bag.
        • Bryan KB
          Rough out of cabins and holds.
            Great result in a difficult topic, have you considered a cabin inside the main fuselage? I think there is a market for this type of aircraft flown at very high altitude as phone and internet communication servers. They could also be used for mapping and lidar purposes. etc et al. A render of this beauty over high cloud and mountains would be about perfect.
            • Bryan KB
              Rough out of the bridge.
              • Bryan KB
                Bridge imported back into main model.
                • Bryan KB
                  Bridge updated and control surfaces added.
                  • Bryan KB
                    Top view.
                    • Bryan KB
                      Engines roughed into place.
                      • Bryan KB
                        Forward lounges and penthouse suites.
                        • Bryan KB
                          Thanks Mike.
                          Yes, the main cabins and holds do extend into the gas bag. I'll post a see-through showing that. Good suggestion. Thanks.
                          • L
                            Nice work Bryan πŸ‘ How did you create the main fuselage, what tool?
                            • Bryan KB
                              I used Curviloft. I first created one quarter using the arc tool, then divided that into three sections and then used Curviloft and turned it into a component.
                              • Bryan KB
                                Here is an xray view showing the cabins extending in the main hull and also the lines used to create the hull that are the initial anchor/guidelines for Curviloft.
                                I will not be making any interior details at this time. The airship is just part of a larger scene I will be making.
                                • Bryan KB
                                  Updates.
                                  • Bryan KB
                                    A close up. Look close and you can the SketchUp man for scale.
                                    • Bryan KB
                                      Bridge update. This will be about all the detail I'll add to the bridge at this time.
                                      The box hanging from the ceiling are long range sensors, but not the only ones.
                                      • Bryan KB
                                        A ground view.
                                        • Bryan KB
                                          Lateral thrusters added.
                                          • Bryan KB
                                            And that's it for the airship for now.
                                            Moving on to the scene it was made for in a new thread.
