    Want to be able to see face shape when editing texture
    8 Posts 3 Posters 2.0k Views 3 Watching
    • G
      Ginger_Overlord
      Is there anyway to to see the shape of a face when amending its texture? Maybe I've missed something, but when editing a texture in Photoshop you only see the original square texture. I have a wing that I want to amend the texture of and it would be really useful to see the actual wing shape as I do this.
      Hope this makes sense.
      Regards,
      Chris.
      • R
        rv1974
        Take a PrintScreen of SU viewport and put it as background layer in Photoshop. What's the problem?
        • S
          shawb
          Select the wing/surface & make it a Unique Texture (right click context menu). Right click context menu again and this time select Texture/Edit Texture Image. This should open the unique texture in your default image editing program and will be the shape of the surface. I use Gimp so post is based on that. Edit as needed and in the Gimp File dropdown click on Overwrite ***.jpg. Back in Sketchup the texture is updated.
          • G
            Ginger_Overlord
            Hi Shawb,
            Brilliant. Thanks for that, exactly what I wanted.
            Cheers πŸ˜„
            • G
              Ginger_Overlord
              Hi Shawb,
              Sorry to be dumb, there doesn't appear to be any 'make unique texture' options when right-clicking any of the faces on my model.
              Cheers,
              G_O
              • S
                shawb
                Make sure that you have only selected the surface/face and not any edges i.e. just one click. If you are working with a group or component you will need to open the group/component for editing and then select just the surface. Hope that helps!
                • G
                  Ginger_Overlord
                  I've taken a look at my model and I'm only selecting one face but the option is missing. I have included a screenshot here.
                  Thanks.
                  G_O
                  Screenshot of missing option
                  • G
                    Ginger_Overlord
                    Hi Shawb,
                    OK, got it. The 'Unique Texture' option doesn't appear if you have the 'Face Style' view set to anything other than 'Shaded with Textures'. I had mine set to monochrome.
                    Makes sense now.
                    Apologies. I can now play around with this πŸ˜„
                    Cheers,
                    G_O
