    Value Control Box Measurement Typing in measurements
    3 Posts 2 Posters 9.0k Views 2 Watching
    • onzkiO Offline
      onzki
      Hi, I want to report a bug in value control box.
      Normally when creating a rectangle or square, I would type in the values separated by a COMMA (,) in value control box to specify my measurement. Example: For a 100x300 rectangle shape, you will type in 100,300.
      However, this comma doesn't work in my other workstation, and took me a year to figure out! (I accidentally observed the value control box while doing a rectangle and the preview values display semi colon instead of the normal comma). So I figured out that the Sketchup in this particular PC only accepts SEMI COLON (;) as separator, no wonder the comma won't work. Example: For a 100x300 rectangle shape, you will type in 100;300. Weird isn't it? I'm using same Sketchup 2018 pro.
      I suggest, play around with the rectangle tool, and the first time you hit mouse button (starting point of rectangle)- values will be displayed automatically corresponding to your mouse movements, and notice the values separator, it may be comma, semi colon or something else. I hope this helps.
      I tested in my 3 PC, only one have this issue.
      All PC's have same region and keyboard/language input (US layout). Only difference is OS.
      PC 1- Win 7 Pro - Sketchup 2018 Pro - comma worked
      PC 2- Win 8 - Sketchup 2018 Pro - Semi colon worked
      PC 3- Win 10 - Sketchup 2018 Pro - comma worked
      For now, I will regard this as a Sketchup bug.
      Hope Trimble can help fix, Thanks!
      Also mentioned in this thread:
      https://sketchucation.com/forums/viewtopic.php?f=15&t=52893&p=638699#p638699
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
        This is not really a 'bug'...
        PC users split into two camps, those in the US/UK/AU/NZ/SA/etc who use a Stop . for the decimal separator and those from the EU/Asia/SouthAmerica/etc who use a Comma , as the decimal separator.
        Entering combo-numerical values needs a list-separator: so . decimal users will need a , and the , decimal users will need a ; [Semi-Colon]
        A user's PC will have 'Regional' settings, specifying what decimal point type to use etc.
        However, it's possible to override the system settings and in an otherwise . decimal setup to reset it to a , !
        If you or someone with access to your PC has changed this, then confusion reigns as you now need to type , for a decimal point and a ; as a separator !
        On a PC you have a Control Panel - it's name varies with OS version, called something like "Region and Language"...
        Here there will be settings for all manner of things like date/time/number-formats, and e.g. what decimal-point type to use ./,
        • onzkiO Offline
          onzki
          TIG, you're eagle eye to spot that, awesome thanks!
