    Edges and Hybrid transparency
    layout
    4 Posts 3 Posters 5.1k Views 3 Watching
    • pbacotP
      I did not know this. If you choose to ues hybrid, arguably the better looking most useful setting in LO, edges seen through transparent surfaces disappear. That's not good. I guess i never needed it but now I have a model that does need the edges to show and there's no way to do that except by raster which is no good by default.
      • S
        shawb
        As a workaround omit the transparent surface in SU but add a transparent shape in LO. Attached example LO. Not great if you have a lot of separate transparent surfaces!
        Hybrid v2015.layout
          There was a bug introduced that caused this. The LO team know about it and it's in the pipeline.
          In the meantime, a work around is an option. Two scenes in SU. One with textures displayed but edges off. The other, Hidden line--black on white. Stack viewports in LO with the top one set to the Hidden line scene and rendered in Vector. The textured scene below rendered in Raster.
          transparency test.pdf
          • pbacotP
            Dave and Brian,
            Thanks for the ideas and examples. I'll try them out!
            Peter
