Components Library
I have created a fairly extensive components library on my laptop. I need to be able to access it from my desktop and can not figure out how to do that. Anyone have any suggestions?
You could upload all the components to the 3D Warehouse so they'd be available to you from both computers. You could copy the library to a directory on your desktop machine. Or if your laptop and desktop are connected to the same local network, you could set up sharing for the directory so you can access the directory on your laptop from your desktop machine.
Keep in mind that you need to be using SketchUp Pro.
I use dropbox to keep all my pcs with the same files.
Register LoginAdvertisement
