    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Trim a Bitmap?
    4 Posts 4 Posters 1.3k Views 4 Watching
      djh
      I have a bitmap, png, of a fruit without a background. when it's imported into SU it has a white background and interferes with the image. Can one Trim a Bitmap?
      • HornOxxH Offline
        HornOxx
        hi - it makes sense to use a png, which is already provided with an alpha channel.
        This "(non-)background" becomes transparent in SkUp already then.
        So you can avoid the redrawing of a contour in SkUp for deleting the white surface then.
        never trust a skinny cook
          A couple of other options exist. You can use TIG's Image Trimmer with a PNG with transparent background. It's part of his SKM Tools which is in the Sketchucation PluginStore. Or you can use BMP Tracer which is available here See this.
          • BoxB Offline
            One of the main benefits of Dave's suggestion of Tig's image trimmer is that the trimmed png will cast a correct shadow rather than a block.
