    Help with intersect faces
    3 Posts 2 Posters 1.5k Views 2 Watching
      DFB
      I cannot, for the life of me, figure out how to intersect faces. Here is a simple example:
      Intersect Faces Example.skp
      This example shows four groups. I would like to intersect the faces and delete the unwanted parts - for example, the ends sticking out should be removed.
      I feel stupid because this should not be difficult. I can do it if I explode each group, select all, and intersect faces. Is that the only way to do this intersection? I ask, because I have had to do it that way on complex intersections and the cleanup takes a long time.
      Thanks for any advice/tips.
        DFB
        Sorry about the example - I did not see that my AddBlocker was preventing the attachment. Here is an attempt after disabling AddBlocker:
          You haven't explained why you want to Intersect these faces inside the groups...
          However, to get intersection lines added into faces which are INSIDE a group, you first need to edit the group [double-click it or select+context-menu > edit], then select-all [Ctrl+A] > context-menu > Intersect with Model.
          New edges will be added into the edit-context where selected faces intersect other objects.
          Back-out of the edit,and repeat editing and intersecting faces in other groups.
          If your aim is to delete parts of a group's geometry to form 'miters' etc, then you might also want to add faces to those 'cut-ends' - by over-drawing edges.
          To see what you are doing more easily you can also chose the toggle in View > Component Edit > Hide Rest of Model [ it works on Groups too ! ]
