    Path animation
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    3 Posts 2 Posters 10.1k Views 2 Watching
    • S
      sigasiempre
      I'm having trouble understanding how to specify a path for an object movement. I've set up some curves by slicing a cone (conic section) and want to use the as paths for an object to follow. However, these curves don't show as paths when I try to set up a movement. I've attached a file with the curves and a sphere I'm trying to animate to follow these curves.
      https://we.tl/rB4ZixWCvM
      Thanks for any help.
      David
      • S
        sigasiempre
        By the way, these conic section curves were made in Sketchup.
        • fredo6F
          fredo6
          You just need to make the conic contours TRUE Sketchup curve (with TIG Weld). Then they will apear as selectable pathes in Animator.
          Fredo
