    Hybrid & Vector Fail to Render XS
    layout
    4 Posts 2 Posters 3.6k Views 2 Watching
      Charlie__V
      Anyone experience viewport(s) failing to render a Cross Section w/Hybrid & Vector? (Raster is OK)
        Charlie__V
        Uploading LO file for anyone that would like to see if same behavior exhibits as in above mentioned.
        Change either of the upper right viewports to Hybrid or Vector, and see if the viewport renders properly.
        Thanks,
        Charlie
        Hybrid/Vector render fail
          I believe there is a known bug related to this and I think the LO team is working on it. Until it gets fixed I would suggest using TIG's Section Cut Face instead of the Section Fill.
            Charlie__V
            [attachment=0:gsx0983f]<!-- ia0 -->Screenshot - 4_19_2018 , 10_27_54 AM.png<!-- ia0 -->[/attachment:gsx0983f]
            Thanks for having a look at this Dave.
            I have historically used TIG’s section cut face (& still do w/more complex cuts)......but with the SU 2018 new section fill and this being a “simple” drawing I used that feature instead.
            Didn’t even occur to me to check that for being the cause........anyhow.......now I am aware......so thanks again for that.
            Charlie
