    Notification to update Trimble connect.
    11 Posts 7 Posters 2.8k Views 7 Watching
    • I Offline
      infovanderwoude.nl
      Hello,
      I keep getting a notification to update the Trimble Connect extension.
      After the update it says in the left below corner One extension updated succesfully, but
      just when i look in the extension manager it tells me "failed to update Trimble Connect.
      Unable to compleet download."
      Every time i open an excisting or a new file, the message pups up that i should update this extension.
      Is ther a way i can solve this problem ?
      • BoxB Offline
        Go to the Extension warehouse in a browser and download it and install it manually using the Install Extension button.
        Once you have done that it next time it wants to update it should be successful.
          samnorth
          I've never been able to disable it either and find it a problem to update.
          I find logging out/in can help updating it but have had to use Box's method above when it's really stubborn.
          • jujuJ Offline
            juju
            This extension is also giving me trouble, it keeps on wanting to update even though I have disabled it.
            *** EDIT ***
            Following Box's advice above did sort it out.
              RogerB
              Since I am not able to uninstall this nuisance, I set up another app to watch the plugin folder and remove it and it seems to work well.
              • I Offline
                infovanderwoude.nl
                Thank you Box, problem solved. πŸ‘
                • N Offline
                  nickchun
                  Yes Thank you Box for that, it seems to have worked for me too. How did you discover that fix? Annoying that Trimble haven't sorted this from SU2017
                  • BoxB Offline
                    The fix is in the updated file. So without the update there is no fix.
                    • N Offline
                      nickchun
                      Is that a chicken or egg situation? If you can't update through SU then we have to start thinking for ourselves to find solutions 😲
                        Bite your tongue! πŸ˜„
                        • N Offline
                          nickchun
                          Ow!
