Texture image size
When setting a texture image size in sketchup is this done visually or do you use the jpg original pixel size?
Thanks in advance
The pixel size of an image is just a parameter of the camera or image program that created the image; it has nothing to do with reality. I usually note the actual size of the item in the image, draw a rectangle that matches one dimension of the item, and then use File->Import with "Use as Texture" selected. Click one corner of the rectangle and then the diagonally opposite corner and the texture will be created sized to the real dimensions.
Register LoginAdvertisement
