    STL Problem
    4 Posts 2 Posters 10.5k Views 2 Watching
    • L
      LTH
      I have a cooling duct I'm trying to design for my printer but I can't get it water tight to print. This is the first time I've tried to make anything like this. I'm attaching the file so you can see what I mean. Thx for any pointers you might have. Thx
      AM8 Cooling Duct.skp
      • TIGT
        There are several issues...
        First your axes are inverted.
        Blue/Z == up
        It's straightforward to Edit>Select>All and rotate it 180°
        Get Thomthom's Solid Inspector to see these...
        There are several issues you must fix manually.
        The 10 circular holes break the surface of the object.
        That immediately renders it a 'non-solid'.
        The 6 similar edge holes create related issue.
        There are also 6 internal face edges...
        A 'solid' must have only faces and edges.
        Every edge must support two faces - no more no fewer !
        Any 'hole' in a surface will, by definition, have edges with only one face !!
        • L
          LTH
          Thx Tig for your help. As you can probably tell I'm very new to Sketchup. I have all the issues resolved and back to a solid but I'm still in the dark as how to get the holes and it still be solid. Can you point me to a tutorial on how to accomplish this? Thx
          • TIGT
            If you expect the circular holes to penetrate into the form, then you need to draw over an edge in the circle to form a face, and PushPull that into the form by the desired dim, to make a recessed cylindrical hole.
            If you want a hole to punch completely through the form, then PushPull it more so it is completely through the form. Now select the new extended cylinder and use the Context-menu > Intersect with Model, to cut the cylinder at the lower surface. Now select the unwanted faces/edges of the cylinder and erase them. You should now have a hole that pass right through the form ?
