    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 728.1k Views 163 Watching
    • FrederikF Offline
      Frederik
      @oxer said:
      HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move.
      But like I wrote...
      I don't have the issue HornOxx is experiencing...
      The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
      Cheers
      Kim Frederik
      • OxerO Offline
        Oxer
        REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
        http://www.oxervision.blogspot.com/
        • FrederikF Offline
          Frederik
          Ok... I've made the frame with 3 slats...
          At first I couldn't make it work - because I had grouped them...
          One IMPORTANT info is missing...
          You need to move the frame-pins one by one...
          It can't be done by moving all three in one go... πŸ€“
          Cheers
          Kim Frederik
          • OxerO Offline
            Oxer
            Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
            • FrederikF Offline
              Frederik
              Got it... πŸ‘
              Hold down the shift-key when clicking the pins and then converge...! πŸ˜„
              This gives me a ton of new options and ideas... πŸ˜„
              Thanks, Oxer...! πŸ‘
              Cheers
              Kim Frederik
              • PixeroP Offline
                Pixero
                For a non native english speaker. Could you explain what converge is?
                Googling it didnt help. πŸ˜•
                • BoxB Offline
                  Bring together.
                  Move toward each other as if to become one.
                  Two paths can converge into one and diverge back into two.
                  • PixeroP Offline
                    Pixero
                    Thanks.
                    • FrederikF Offline
                      Frederik
                      Strange...
                      I get a lot of results - especially if I write "define: converge" in Google... πŸ˜„
                      Even Google translate has a nice explanation...
                      Cheers
                      Kim Frederik
                      • N Offline
                        notareal
                        Nice work with this!
                        • PixeroP Offline
                          Pixero
                          Strange...
                          What I meant was simply that I didn’t understood the meaning of the word using Google.
                          • FrederikF Offline
                            Frederik
                            No worries, Jan... I actually just wanted to make you aware of the "define: xxxxx" option available in Google...
                            I'm fairly sure you would have found reasonable explanation and understanding if you had used that option...
                            Cheers
                            Kim Frederik
                            • OxerO Offline
                              Oxer
                              A new use for ClothWorks, create organic shapes, rendering with Thea Render.
                                Excellent! But it needs a meatball and some grated parm. πŸ˜„
                                • OxerO Offline
                                  Oxer
                                  It isn't finished, I'm cooking yet. πŸ˜† πŸ˜†
                                  • BoxB Offline
                                    It's a great out of the box use of clothworks, but it just makes me more interested in the msphysics/clothworks hybrid.
                                    I want to drop the clothworks sloppy spaghetti into the bowl using physics.
                                    The combined plugin is more than the sum of its parts.
                                    • OxerO Offline
                                      Oxer
                                      The spaghettis are curves-clothes, the plate is a collider, play the simulation and the spaghettis are placed over the plate, so the simulation is very fast. Then you can give volume to the curves-clothes with tape maker plugin. The tomatoe sauce is a cloth too, the spaghettis with volume are colliders and run simulation again.
                                      • BoxB Offline
                                        True, but there are refinements to the process that would make things better.
                                        If the spaghetti had proper density so they interact physically with each other and you get the cloth like flexibility with the solidity of pasta.
                                        Or as I mentioned way back, being able to drop solid objects into a flexible container.
                                        Marbles into a bag, or Potatoes into a sack, without having to do all the clever frames and converging.
                                        • OxerO Offline
                                          Oxer
                                          That would be fantastic but that is work of the developer Anton, for the moment I use the current possibilities of the plugin.
                                          • HornOxxH Offline
                                            HornOxx
                                            ... for you it's just "cooking" - for me it's pure fascinating magic and I'm amazed like a child πŸ˜„
                                            A great idea and excellently realized !!
                                            btw, I prefer Spaghetti Arrabiata
                                            never trust a skinny cook
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 35
                                            • 36
                                            • 13 / 36
