    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 844.3k Views 165 Watching
    • FrederikF Offline
      Frederik
      @oxer said:
      REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
      Ok... I've made the frame with 3 slats...
      At first I couldn't make it work - because I had grouped them...
      One IMPORTANT info is missing...
      You need to move the frame-pins one by one...
      It can't be done by moving all three in one go... πŸ€“
      Cheers
      Kim Frederik
      • OxerO Offline
        Oxer
        Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
        • FrederikF Offline
          Frederik
          Got it... πŸ‘
          Hold down the shift-key when clicking the pins and then converge...! πŸ˜„
          This gives me a ton of new options and ideas... πŸ˜„
          Thanks, Oxer...! πŸ‘
          Cheers
          Kim Frederik
          • PixeroP Offline
            Pixero
            For a non native english speaker. Could you explain what converge is?
            Googling it didnt help. πŸ˜•
            • BoxB Offline
              Bring together.
              Move toward each other as if to become one.
              Two paths can converge into one and diverge back into two.
              • PixeroP Offline
                Pixero
                Thanks.
                • FrederikF Offline
                  Frederik
                  Strange...
                  I get a lot of results - especially if I write "define: converge" in Google... πŸ˜„
                  Even Google translate has a nice explanation...
                  Cheers
                  Kim Frederik
                  • N Offline
                    notareal
                    Nice work with this!
                    • PixeroP Offline
                      Pixero
                      Strange...
                      What I meant was simply that I didn’t understood the meaning of the word using Google.
                      • FrederikF Offline
                        Frederik
                        No worries, Jan... I actually just wanted to make you aware of the "define: xxxxx" option available in Google...
                        I'm fairly sure you would have found reasonable explanation and understanding if you had used that option...
                        Cheers
                        Kim Frederik
                        • OxerO Offline
                          Oxer
                          A new use for ClothWorks, create organic shapes, rendering with Thea Render.
                            Excellent! But it needs a meatball and some grated parm. πŸ˜„
                            • OxerO Offline
                              Oxer
                              It isn't finished, I'm cooking yet. πŸ˜† πŸ˜†
                              • BoxB Offline
                                It's a great out of the box use of clothworks, but it just makes me more interested in the msphysics/clothworks hybrid.
                                I want to drop the clothworks sloppy spaghetti into the bowl using physics.
                                The combined plugin is more than the sum of its parts.
                                • OxerO Offline
                                  Oxer
                                  The spaghettis are curves-clothes, the plate is a collider, play the simulation and the spaghettis are placed over the plate, so the simulation is very fast. Then you can give volume to the curves-clothes with tape maker plugin. The tomatoe sauce is a cloth too, the spaghettis with volume are colliders and run simulation again.
                                  • BoxB Offline
                                    True, but there are refinements to the process that would make things better.
                                    If the spaghetti had proper density so they interact physically with each other and you get the cloth like flexibility with the solidity of pasta.
                                    Or as I mentioned way back, being able to drop solid objects into a flexible container.
                                    Marbles into a bag, or Potatoes into a sack, without having to do all the clever frames and converging.
                                    • OxerO Offline
                                      Oxer
                                      That would be fantastic but that is work of the developer Anton, for the moment I use the current possibilities of the plugin.
                                      • HornOxxH Offline
                                        HornOxx
                                        ... for you it's just "cooking" - for me it's pure fascinating magic and I'm amazed like a child πŸ˜„
                                        A great idea and excellently realized !!
                                        btw, I prefer Spaghetti Arrabiata
                                        never trust a skinny cook
                                        • OxerO Offline
                                          Oxer
                                          Thanks!! When I finish the "cooking" I will upload the final plate. πŸ˜‰
                                          • BoxB Offline
                                            I'm looking forward to seeing the freshly shaved Parmesan and the enormous pepper mill grinding away.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 35
                                            • 36
                                            • 13 / 36
