    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 171 Watching
    • OxerO
      Oxer
      HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
      REMEMBER: The cloth should enter a little in the frame.
      • FrederikF
        Frederik
        But like I wrote...
        I don't have the issue HornOxx is experiencing...
        The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
        Cheers
        Kim Frederik
        • OxerO
          Oxer
          REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
          • FrederikF
            Frederik
            Ok... I've made the frame with 3 slats...
            At first I couldn't make it work - because I had grouped them...
            One IMPORTANT info is missing...
            You need to move the frame-pins one by one...
            It can't be done by moving all three in one go... πŸ€“
            Cheers
            Kim Frederik
            • OxerO
              Oxer
              Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
              • FrederikF
                Frederik
                Got it... πŸ‘
                Hold down the shift-key when clicking the pins and then converge...! πŸ˜„
                This gives me a ton of new options and ideas... πŸ˜„
                Thanks, Oxer...! πŸ‘
                Cheers
                Kim Frederik
                • PixeroP
                  Pixero
                  For a non native english speaker. Could you explain what converge is?
                  Googling it didnt help. πŸ˜•
                  • BoxB
                    Bring together.
                    Move toward each other as if to become one.
                    Two paths can converge into one and diverge back into two.
                    • PixeroP
                      Pixero
                      Thanks.
                      • FrederikF
                        Frederik
                        Strange...
                        I get a lot of results - especially if I write "define: converge" in Google... πŸ˜„
                        Even Google translate has a nice explanation...
                        Cheers
                        Kim Frederik
                        • N
                          notareal
                          Nice work with this!
                          • PixeroP
                            Pixero
                            Strange...
                            What I meant was simply that I didn’t understood the meaning of the word using Google.
                            • FrederikF
                              Frederik
                              No worries, Jan... I actually just wanted to make you aware of the "define: xxxxx" option available in Google...
                              I'm fairly sure you would have found reasonable explanation and understanding if you had used that option...
                              Cheers
                              Kim Frederik
                              • OxerO
                                Oxer
                                A new use for ClothWorks, create organic shapes, rendering with Thea Render.
                                  Excellent! But it needs a meatball and some grated parm. πŸ˜„
                                  • OxerO
                                    Oxer
                                    It isn't finished, I'm cooking yet. πŸ˜† πŸ˜†
                                    • BoxB
                                      It's a great out of the box use of clothworks, but it just makes me more interested in the msphysics/clothworks hybrid.
                                      I want to drop the clothworks sloppy spaghetti into the bowl using physics.
                                      The combined plugin is more than the sum of its parts.
                                      • OxerO
                                        Oxer
                                        The spaghettis are curves-clothes, the plate is a collider, play the simulation and the spaghettis are placed over the plate, so the simulation is very fast. Then you can give volume to the curves-clothes with tape maker plugin. The tomatoe sauce is a cloth too, the spaghettis with volume are colliders and run simulation again.
                                        • BoxB
                                          True, but there are refinements to the process that would make things better.
                                          If the spaghetti had proper density so they interact physically with each other and you get the cloth like flexibility with the solidity of pasta.
                                          Or as I mentioned way back, being able to drop solid objects into a flexible container.
                                          Marbles into a bag, or Potatoes into a sack, without having to do all the clever frames and converging.
                                          • OxerO
                                            Oxer
                                            That would be fantastic but that is work of the developer Anton, for the moment I use the current possibilities of the plugin.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 36
                                            • 37
                                            • 13 / 37
