    2001 Monolith on Moon + +
    26 Posts 6 Posters 13.7k Views 6 Watching
    • tuna1957T Offline
      tuna1957
      Might have bit off more than I can chew with this. Started a model of the 2001 Space Odyssey scene of the monolith excavation on the moon. Found some reasonably decent reference pics. Posting a couple of views of were I'm at with it. Have already remodeled the walls and supports, the first version I wasn't very happy with. Plenty more to do. I'll post pics as I move along with it. This might take a while ๐Ÿ˜ฎ .
      • HornOxxH Offline
        HornOxx
        ๐Ÿ‘ ๐Ÿ‘ great storytelling - I look forward to the next steps.
        there's a very fitting special exhibition here at the Filmmuseum Frankfurt right now ๐Ÿ˜„ ๐Ÿ˜„
        https://deutsches-filminstitut.de/filmmuseum/ausstellungen/sonderausstellung/
        https://deutsches-filminstitut.de/wp-content/uploads/2017/12/2001-769x328-sk2.jpg
        never trust a skinny cook
          Fascinating start there.
          • tuna1957T Offline
            tuna1957
            Mike, HornOxx, thanks gentlemen. HornOxx, checked out the link you posted.... way cool exhibit. Wish a museum in my area did something like that. ๐Ÿ‘
            • tuna1957T Offline
              tuna1957
              Making progress.... I think. ๐Ÿ˜ฎ Have most of the bits and pieces modeled. Still have to do some work on the terrain and lights. Hope to start test renders, tweaking textures and lights. Maybe have some final renders by next week. Posting a couple of more shots of where things are at now.
              • BoxB Offline
                No doubt you'll be draping a cloth over the monolith to keep out prying eyes until such time as you unveil it.
                • tuna1957T Offline
                  tuna1957
                  Aha.... now I have a reason to download "ClothWorks" ๐Ÿ˜Ž .
                  • Bryan KB Offline
                    Holy cow! That's a lot of modeling!
                    Excellent work!
                    • tuna1957T Offline
                      tuna1957
                      Thanks Bryan. Yep there's quite a bit of stuff in the model. Thank goodness for components.
                      One final raw SU image. Have all my textures worked out ( I think ). This scene is rendering on my iMac right now. Created a fair number of "custom" textures for this one.
                      Thought about dropping a cloth over the monolith for this post as suggested by Box. Unfortunately not going to be able to play with ClothWorks until I upgrade from SU2015pro. ๐Ÿ˜’ . So I gift wrapped it instead ๐Ÿ˜‰ .
                        I like where this is going, nicely done dood.
                        • tuna1957T Offline
                          tuna1957
                          Thanks Mike. If all goes well should have some renders to post in the next couple of days.... ๐Ÿ‘
                          • tuna1957T Offline
                            tuna1957
                            Well for better or worse got a render of this thing finished. Hooray ! Rendered in Twilight. Lots of post pro. Probably did more post pro to this than anything else I've done. Still trying hard to get better at it.... Had to do quite a lot of fiddling with the light set up and textures to get something I thought was pretty good for me. Also posting a mono hidden line view of the scene. Think it looks pretty cool on it's own. Going to try and do some additional views as time allows. Hope you enjoy, have had fun working on it. ๐Ÿ‘
                            • pbacotP Offline
                              Oh Yeah Wow. That's really good! The lighting looks very much like the big flood ligts would produce. For the ones in view did you use emitter textures? Great glow in the back and star field!
                              • tuna1957T Offline
                                tuna1957
                                Thanks pbacot. As for the lights, your correct all the lenses of the floodlights are fake emitters. Think I had the power at 1000 watts. For real light I used point lights just in front of the lenses and loaded the .ies files for actual floodlights that I downloaded off various light manufacturers websites. The small floods down the ramps each have an .ies flood that gives off 3000 lumens. The gang lights all have an .ies file for a flood rated at 20,000 lumens. The two gang lights facing the camera each have three 20,000 lumen floods spaced in a triangle. There's three gang lights just behind the camera position. Those have four of the 20,000 lumen floods spaced out in front. Also had the sun on. Set to Sky Color. Sun Strength 2.0 , Brightness 0.600 . Set the sky color to a grey R-70, G-70, B-70.
                                • pbacotP Offline
                                  Fastly error: unknown domain 151.101.64.81
                                  (www.bbc.com)
                                  • tuna1957T Offline
                                    tuna1957
                                    Well here you go with another view. Turned out better than I thought it was going to. This view really pushed my very basic post pro skills...... enjoy ๐Ÿ‘ .
                                      Wow, dood, you nailed that. Brilliant.
                                      • tuna1957T Offline
                                        tuna1957
                                        Thanks Mike.
                                        • HornOxxH Offline
                                          HornOxx
                                          @mike amos said:
                                          ...you nailed that...
                                          ๐Ÿ‘ yes, you did! love this work!!!!
                                          • tuna1957T Offline
                                            tuna1957
                                            Thanks HornOxx. It was a fun modeling and rendering challenge. Learned a lot in the process. ๐Ÿ‘
                                            • 1 / 2
