    2001 Monolith on Moon + +
    26 Posts 6 Posters 12.8k Views 6 Watching
    • tuna1957T Offline
      tuna1957
      Making progress.... I think. ๐Ÿ˜ฎ Have most of the bits and pieces modeled. Still have to do some work on the terrain and lights. Hope to start test renders, tweaking textures and lights. Maybe have some final renders by next week. Posting a couple of more shots of where things are at now.
      • BoxB Offline
        No doubt you'll be draping a cloth over the monolith to keep out prying eyes until such time as you unveil it.
        • tuna1957T Offline
          tuna1957
          Aha.... now I have a reason to download "ClothWorks" ๐Ÿ˜Ž .
          • Bryan KB Offline
            Holy cow! That's a lot of modeling!
            Excellent work!
            • tuna1957T Offline
              tuna1957
              Thanks Bryan. Yep there's quite a bit of stuff in the model. Thank goodness for components.
              One final raw SU image. Have all my textures worked out ( I think ). This scene is rendering on my iMac right now. Created a fair number of "custom" textures for this one.
              Thought about dropping a cloth over the monolith for this post as suggested by Box. Unfortunately not going to be able to play with ClothWorks until I upgrade from SU2015pro. ๐Ÿ˜’ . So I gift wrapped it instead ๐Ÿ˜‰ .
                I like where this is going, nicely done dood.
                • tuna1957T Offline
                  tuna1957
                  Thanks Mike. If all goes well should have some renders to post in the next couple of days.... ๐Ÿ‘
                  • tuna1957T Offline
                    tuna1957
                    Well for better or worse got a render of this thing finished. Hooray ! Rendered in Twilight. Lots of post pro. Probably did more post pro to this than anything else I've done. Still trying hard to get better at it.... Had to do quite a lot of fiddling with the light set up and textures to get something I thought was pretty good for me. Also posting a mono hidden line view of the scene. Think it looks pretty cool on it's own. Going to try and do some additional views as time allows. Hope you enjoy, have had fun working on it. ๐Ÿ‘
                    • pbacotP Offline
                      Oh Yeah Wow. That's really good! The lighting looks very much like the big flood ligts would produce. For the ones in view did you use emitter textures? Great glow in the back and star field!
                      • tuna1957T Offline
                        tuna1957
                        Thanks pbacot. As for the lights, your correct all the lenses of the floodlights are fake emitters. Think I had the power at 1000 watts. For real light I used point lights just in front of the lenses and loaded the .ies files for actual floodlights that I downloaded off various light manufacturers websites. The small floods down the ramps each have an .ies flood that gives off 3000 lumens. The gang lights all have an .ies file for a flood rated at 20,000 lumens. The two gang lights facing the camera each have three 20,000 lumen floods spaced in a triangle. There's three gang lights just behind the camera position. Those have four of the 20,000 lumen floods spaced out in front. Also had the sun on. Set to Sky Color. Sun Strength 2.0 , Brightness 0.600 . Set the sky color to a grey R-70, G-70, B-70.
                        • pbacotP Offline
                          http://www.bbc.com/culture/story/20180404-why-2001-a-space-odyssey-remains-a-mystery
                          • tuna1957T Offline
                            tuna1957
                            Well here you go with another view. Turned out better than I thought it was going to. This view really pushed my very basic post pro skills...... enjoy ๐Ÿ‘ .
                              Wow, dood, you nailed that. Brilliant.
                              • tuna1957T Offline
                                tuna1957
                                Thanks Mike.
                                • HornOxxH Offline
                                  HornOxx
                                  @mike amos said:
                                  ...you nailed that...
                                  ๐Ÿ‘ yes, you did! love this work!!!!
                                  never trust a skinny cook
                                  • tuna1957T Offline
                                    tuna1957
                                    Thanks HornOxx. It was a fun modeling and rendering challenge. Learned a lot in the process. ๐Ÿ‘
                                    • Bryan KB Offline
                                      Excellent!
                                      • tuna1957T Offline
                                        tuna1957
                                        Thanks Bryan.
                                        • HornOxxH Offline
                                          HornOxx
                                          In real Touch with HAL
                                          Hello Charles, hello All - above I mentioned the special exhibition "50 years 2001" of the Film Museum in Frankfurt and today I finally found the time to visit this - a great time, already the nice detail of the internal museum signage 3rd floor was nicely done ๐Ÿ˜„
                                          Unfortunately there are no more physical artifacts of the monolith left, so i photographed the lego-like monolith toy with the monkey at least.
                                          I can't imagine how big Kubrickยดs advantage would have been, if you and your SkUp skills had been part of his team.
                                          There was an about 4 m long Spacecraft Discovery model next to the moonbus and other models, the original space child even!, original space suits with helmets and equipment, lots of original script sketches and even: Hal - I touched it/him ๐Ÿ˜‰ as the guard looked in the other direction ๐Ÿ˜„ somehow I expected this reddish candle-like light and this strange voice telling me "I can't let you go home with your car"...
                                          From your great model scene there are some original hand sketches and set photos at least and: with your model here you're pretty damn close to this set, obviously ๐Ÿ‘ ๐Ÿ‘
                                          I dont have a good mobile phone camera - it was very dark of course and using flashlight was not allowed, yet I'll add some photo impressions here and I hope youยดll like it ...
                                          Best
                                            Nice, thanks for those. Blurry brilliant to see.
