    Adjust a dark photo?
    20 Posts 6 Posters 5.2k Views 6 Watching
    • Joe WoodJ Offline
      Joe Wood
      I'm scanning some old pre 1990 project photos and they're coming out a bit darkish. I just barely use Corel Paint and Draw, don't know much about manipulating images like this. I played with the brightness though and got some nice results ๐Ÿ™‚
      what else could I do to improve this image?
      BTW This house was built here in San Diego for the Chinese ambassador in the early 30s!
      I did the roofed entry and fencing work. Twice I was turned down when I asked the owner if he'd let me go up in to the attic. I wanted to see how that roof was framed!! I wish I had been more persistent!
      here's the original, the gate is just a black rectangle. In the one above I can just see the vertical batts on the double gates.
      Joe Wood
      woodsshop.com/
        I think being too persistent may cause a bigger problem in the long run. I would be looking for local planning body files, there should be decently detailed prints for the area's you want to see.
        https://www.sandiegohistory.org/library_programs/
        • Joe WoodJ Offline
          Joe Wood
          I doubt there were any photos taken during this time, if I understand your answer Mike, besides I want to understand how to adjust dark photos like this.
          Joe Wood
          woodsshop.com/
          • pbacotP Offline
            My experience the local planning / building departments barely have records, let alone drawings prior to the last couple decades. Somehow, asking for multiple copies, they lose or destroy them all or never put them on film. Now they will likely get scanned and put on an antiquated computer network. The departments barely existed in the early 20th century.
            • Joe WoodJ Offline
              Joe Wood
              Plus I took this photo around 1991.
              So how else can I improve these photos besides the brightness, contrast and intensity?
              Joe Wood
              woodsshop.com/
              • tuna1957T Offline
                tuna1957
                Joe, If I understand correct , your wanting to "brighten up" the area of the gate. If that's the case your starting to cross into some more advanced territory with an image editor. I'm by far no master at this but I took your pic into Gimp to see what I could do. Biggest roadblock for me is not knowing what the gate actually looks like. Reposting the pic to show where I ended up. Will try and describe what I did....
                First I cropped the white border off the top of the image. Ran the "Auto White Balance" tool. Used the "Curves" tool to brighten up the image. I have found the "Curves" tool doesn't screw the colors of image up as bad when trying to brighten up dark images as much as using "Brightness & Contrast" does.
                Now the fun begins. Used the "Select by Color" tool to select the area of the gate. The "Curves" tool brightened this area up but the colors got pretty whacked out. Had to use "Color Balance" and "Hue & Saturation" tools along with the "Scissors Select" tool to try and work the color back where I thought it looked o.k. When I got the gate looking reasonably decent did minor "Hue & Saturation", "Brightness & Contrast" on the whole image and there you have it. Hope this long winded example helps some.
                • Bryan KB Offline
                  This is the best I could, There simply isn't enough light to work with.
                    Understood but by my thinking, the roof framing should be in the planning permission papers.
                    • Joe WoodJ Offline
                      Joe Wood
                      Thanks for going to all the work for me Tuna but I don't use Gimp so don't understand hardly any of those commands you mentioned. The photo came out pretty well though! I was wanting to not just lighten up the gate but the whole image.
                      Can you explain what you did Bryan, and what program you used? Yours came out pretty well too!
                      Mike I understand what you meant now, that's a good point about the planning Dept!
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ Offline
                        Joe Wood
                        This is another original scan I made, you can see how dark it is.
                        and then me just playing with the Brightness and Contrast a little, and pushing up the Intensity this time, did I set those three Settings well?
                        and I'm pretty happy with it ๐Ÿ™‚ and it was easy 1 step.
                        Bryan's looks a little better, so when I'm looking at the Tools in that Adjust menu, if I had to choose 1 more Tool to use would it be Hue / Saturation?
                        Joe Wood
                        woodsshop.com/
                        • Bryan KB Offline
                          I used an old verison of Adobe Fireworks. It has much of the same adjustments as Adobe Photoshop of that era.
                          I did several things:
                          The curves (just used auto adjust)
                          The brightness contrast
                          Hue adjustment. There was too much red in the picture
                          Sharpen (yep, sharpen)
                          Then ran the above again.
                          So basically, just minimal Photoshop tweaks.
                          • Joe WoodJ Offline
                            Joe Wood
                            Hhmmm, Hue and Sharpen. I'll play with those!
                            what are these 'curves' Bryan, can you explain?
                            Joe Wood
                            woodsshop.com/
                            • Bryan KB Offline
                              Tone curve. Looks like curvy line inside a a box. You can actually grab the line itself and drag it diagonally. Usually up and to the left. Not very far either.
                              • Bryan KB Offline
                                Update
                                • tuna1957T Offline
                                  tuna1957
                                  Joe, Going to throw one more thing your way.... What resolution are you scanning your originals at ? Higher resolution scans give way more information for the software to work with when doing edits/fixes. The fixed image can always be scaled down if needed for posting on the web.
                                  • Joe WoodJ Offline
                                    Joe Wood
                                    I was going to ask about the initial scanning.
                                    I put a 4x6" photo on the scanner and scan at a high setting.
                                    the image plus scanner table area scans at 6800x8800
                                    then when I crop the image it's 4600 pixels wide.
                                    Joe Wood
                                    woodsshop.com/
                                    • tuna1957T Offline
                                      tuna1957
                                      Joe , You can adjust your scanner so it only scans the image. Saves having to go back in and crop out the dead space.
                                      • Joe WoodJ Offline
                                        Joe Wood
                                        Just discovered the Professional Mode, and see some more settings but nowhere to scan only the image?
                                        Joe Wood
                                        woodsshop.com/
                                        • tuna1957T Offline
                                          tuna1957
                                          Joe, Took a few minutes... had to unpack the Epson scanner. Haven't used it since packing up from the museum job I was on. You make your adjustments in the preview window. Attached screenshot, hope it helps.
                                          • andybotA Offline
                                            andybot
                                            Definitely use "curves" adjustment. Brightness/ contrast is an older mode and gives you much less control. I would highly recommend Lightroom. It's non-destructive and has a really great set of controls for color adjustments. When you scan - set the bit depth as high as the scanner will let you - that will give your image editing program more information to work with.
