    Joint-pushpull direction weird - help!
    2 Posts 2 Posters 2.0k Views 2 Watching
      dohyungkim
      Hi!
      I did joint pushpull and other to do like image below but the direction went bit off.
      the right pushpulled edge's not matching to the extending line from the center of the
      circle.
      I don't know why. can anyone tell me why this happened??
      • fredo6F Offline
        fredo6
        @dohyungkim
        By default, JointPushPull, Joint Tool, uses the neighbour faces to constrain the direction, even if these faces are not part of the selection. You can disable this feature with one option which is in the button palette ("neighbour influence...").
        I also recommend you migrate to the newest version of JointPushPull, v4.2a.
        Fredo
